Page: |
Home > A-Series EFI / Injection > Monitoring AFR balance in a boosted engine | |||||||
62 Posts Member #: 1515 Advanced Member |
12th Mar, 2007 at 09:08:09am
With sequential code getting close to testing, there is one thing that has been bothering me. When calibrating up the staging to a particular engine/Cam/inlet combo you need to measure the imbalance between outer and inner cylinders at a number of load and RPM points. Now with a natasp this is easy, as you just weld a pair of lambda sensor bosses in and either do 2 sets of logs, or for the well heeled fit 2 widebands. For a turbo you cannot do this as nernst cells neither like the high temps or high pressures of a pre-turbo exhaust.
Edited by bill shurvinton on 12th Mar, 2007. |
6745 Posts Member #: 828 Post Whore uranus |
12th Mar, 2007 at 09:34:49am
id go for the ex temp probes bill , the innovate aux box can take a couple i think.
12th Mar, 2007 at 10:03:22am
It can and logworks is now MS compatible ( and a great analysis tool), but that is an additional cost to those on a budget. I'll need to check, but there might just be enough analogue inputs on MS2 to log them natively with a little additional PCB, which would at least be neat. |
4559 Posts Member #: 786 Post Whore Bermingum |
12th Mar, 2007 at 10:07:32am
12th Mar, 2007 at 10:14:37am
Both. You need to do a correction for EBP (which none of the currently available hobbyist units do) and they get very grumpy above 750C. |
12th Mar, 2007 at 01:31:43pm
I know from Carl Austin's mini that with the centre-branch seeing twice as many pulses as the outer branches, it ran a lot hotter. I don't see that this will therefore be accurate enough?
12th Mar, 2007 at 02:28:55pm
The correction for EBP might not be necessary if you only want to see relative variation of AFR between cylinders. So for timing purposes, you could just see if you get the same reported AFR for outside and middle branches but to get the correct AFR, you'd need to have a wideband after the turbo for both pressure and temperature reasons mentioned.
12th Mar, 2007 at 03:10:50pm
I use the extra board, and have a small stash of the AD 595 for one offs. The problem is that you cannot easily fit MS2 and the error* board in a standard case, and the wiring is a bit of a monster. When the higher case becomes available this will be eased. OTOH it does have a basic knock detect on as well, which could be of use.
12th Mar, 2007 at 06:13:10pm
It would probably be a good idea to have a board more dedicated to the MS2 V3 setup. The error* board was designed for the MS1/extra V2.2 setup and has some no-longer necessary stuff.
Edited by jbelanger on 12th Mar, 2007. |
12th Mar, 2007 at 07:13:03pm
how about temp sensor rings placed under each plug ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
12th Mar, 2007 at 08:10:18pm
i liked stevies idea of small diameter pilot tubes comeign out the centre and side branch, in which wideband lambda's are located.
12th Mar, 2007 at 10:15:13pm
Sadly you have violated some laws of physics there. You could build a venturi off the main exhaust, but that is a lot of work compared to a pair of EGT probes. Remember, after you have balanced things then you can do all the tuning post turbo. |
12th Mar, 2007 at 11:29:02pm
I must admit that I was thinking along the same lines as TD.
13th Mar, 2007 at 12:06:35am
I agree that until a tuning method for injection timing has been established and initial ballpark figures have been found, I wouldn't try to tune a boosted engine. I was just saying that once this is done then the EGT probes could be used to check that the lambda sensors are safe. You could also see how closely you can rely on EGT for balance tuning purposes.
13th Mar, 2007 at 12:09:05am
I agree Jean. If I was to do a boosted motor at this time I'd do the same as TD suggests, lock the wastegate open and run it fairly gently. Every day is a school day ...........
13th Mar, 2007 at 12:51:08am
The temperature of the exhaust gas will be the same it is just that the outer runners will have more time to conduct heat away before the next pulse. Given the slow reaction time of EGT this would be averaged out.
13th Mar, 2007 at 05:24:02am
The problem with running the engine without boost and/or gently is that you then have a smaller injection pulse width. This means that you're using a smaller percentage of the injection window which means you have to play more with the injection timing going back and forth to find the correct angle.
13th Mar, 2007 at 07:19:18am
That is a good point Jean, less of an issue for staged injectors, but for a single pair of injectors it would be more so.
13th Mar, 2007 at 11:55:32pm
bill i was talkign about having two relaitvely small tubes comeing off the manifold and venting to atmosphere with a small chamber and the wideband in the flow. as manifold pressure will always be greater than atmospheric, it will allow for constant sampling of the exaust gasses. only trouble i see with this is contamination of the sample in one runner when another runners port is exhausting. more complicated than 2 (or 3) EGT probes but gets around the issue of the centre branch running hotter than the outer two, as the centre branch is bound not to be exactly twice as hot as the outer branches and that then leaves the question of how do you know what temperature difference indicates a balanced mixture. turbo 16v k-series 11.9@118.9 :)
14th Mar, 2007 at 12:52:34am
Hmmm. I call that a wastegate. But one that is always open.
14th Mar, 2007 at 01:54:32am
. Edited by bill shurvinton on 14th Mar, 2007. |
14th Mar, 2007 at 10:04:51pm
I get you. . thermodynamics was never my strong point :) still i dotn see a problem running dual wideband in the setup i described, if sensible sized capillary tubes are used the pressure/flow loss from the perspective of the turbo would be very minimal still EGT is certainly cheaper and cleaner to implement. turbo 16v k-series 11.9@118.9 :)
Page: |
