Page: |
Home > A-Series EFI / Injection > eaton supercharger and mpi | |||||||
17 Posts Member #: 1555 Member |
4th Mar, 2007 at 07:07:56pm
hi there am currently building an eaton powered mpi am going to utilise the original manifold with 2 injectors on then fit a third injector in the plenum for when it comes up on boost using a 52mm throttle jenvey throttle body the engine spec is as follows
4th Mar, 2007 at 07:12:07pm
thats a lot of cam for a forced induction engine. On 28th Aug, 2011 Kean said:
4th Mar, 2007 at 07:18:27pm
it is the avonbar phase 3 turbo cam just under 300 degrees
4th Mar, 2007 at 07:25:59pm
do a search for phase 2 and phase 3,
4559 Posts Member #: 786 Post Whore Bermingum |
4th Mar, 2007 at 07:27:03pm
4th Mar, 2007 at 07:37:12pm
Actually, the injector pulse time is not the main problem. The injector timing is, unless you're planning on keeping the standard ECU and only controlling the third injector with the MS2. If you want to control all the injectors with Megasquirt then you'll have a problem with injector timing even if you can get enough fuel from the injectors.
4th Mar, 2007 at 07:37:40pm
already had the camshaft as was gonna do a turbo conversion but as all project cars they do get alittle more exotic as time goes on
4th Mar, 2007 at 07:40:57pm
if i only use 2 injectors with your code then they will have to be very big and then they will cause other probs what is your recommendations are there any other management packages out there that will support what i want
4th Mar, 2007 at 08:02:16pm
That's why I developed the code: there is nothing out there available that can be used with the siamese ports.
4th Mar, 2007 at 09:23:42pm
Jean, am I correct that your code will work with staged injectors using the staging control in the normal Extra code? If so you could run 2 small injectors in the standard position to deal with the idle and low level running and the larger ones to cope with high boost etc.
4th Mar, 2007 at 09:35:10pm
Roger,
4th Mar, 2007 at 09:59:57pm
Jean,
5th Mar, 2007 at 08:22:30am
yeh i understand the timing of the injectors on the port is critical and that the siamesed ports are difficult with 2 injectors cos of the injector firing order. but could the megasquirt be used set up as 4 injector sequential then splice together the outputs for injectors 1/2 with diodes so current only flows one way to injector 1 and 3/4 spliced together for injector 2 is this possible thanks
5th Mar, 2007 at 10:13:17am
Page: |
