Home > 998cc > machining pockets
chappers
Member #: 1428
Cleveleys
Wondered if anyone had a template for machining pockets into 998 block to accept 12g940 head?
cheers
998 turbo in progress.... DONE..........KNACKERED LOL
there was one floating around on MF a year or so ago (maybe more), one you could print off and use as a template i think.
chappers
Member #: 1428
Cleveleys
right oh cheers bud
Set your 1275 head onto it, and let the valves mark the head with some sort of marking compound ( remove springs obviously )
I ground mine out using dopey grinding stones and a drill. First time around I didnt seal off the cylinders properly, and after a few miles, my rings were knackered :S
Didnt do that again !!! I taped off the cylinder, twice, to ensure no grinding dirt got anywhere near the pistons.
Or you could just grind as far to the 1275 gasket line as you can, smoothing a lot bigger than the valve head itself, Might help de-shroud the valve from the bore.
chappers
Member #: 1428
Cleveleys
thank for that, the university technician and i are going to use the CMM machine to measure the centre distance and diameter of the pocket in relation to the centre of the bore on my knackered block to get the accurate offset. taking the a tangent of the bore as a datum. I've only used the machine once before so i'm not really confident i'll get it right*oh well* Was hoping there would be a template on the web i could just input the co-ordinates into the vertical mill and go for it.
Sounds complicated !!!
I did mine with the engine in the car, using a hand drill, guessing where to grind, with some of those cheap pink grinding stones lol.
The Des Hamill book states that you should use a 35mm dia flycutter and cut between 5 and 6mm into the bore wall, depending on valve size.
Depth of cut depends on valve lift.
chappers
Member #: 1428
Cleveleys
The pockets are off centre from the bore though. Luckily i have a block to take measurements from. When i get some i'll post a template on this website.
This week i put some new cam bearings in the new block, i'm going to tap the 1/4" holes on the underside to the next size, make a centre main strap and have a go at milling a dish in the pistons. Not sure what size yet though as i haven't calculated the CR.
chappers
Member #: 1428
Cleveleys
Alright, i got the measurements done on the CMM to 4 decimal places!! Centre of the bore is the datum and the offset is to the centre of the pocket. this one is for bore no4+2 just invert the measurements for No3+1.
http://www.turbominis.co.uk/index.php?p=20&id=3301
Edited by chappers on 21st Feb, 2007.
akirch
Member #: 399
Austria
"The Des Hamill book states that you should use a 35mm dia flycutter and cut between 5 and 6mm into the bore wall, depending on valve size.
Depth of cut depends on valve lift."
Referring to this topic I did the pocket milling yesterday:
http://www.minifreunde.at
Saint
Member #: 1909
Cracow, PL
How much did You cut into the bore? It looks something like 3-4mm.
akirch
Member #: 399
Austria
1,8mm deep, 5mm wide.
The deepness is measured to my cam/cylinderhead, so i think it`s variable to any other engine...
hario
Member #: 2885
**Depth.. lol
Machined them into a built engine?? ..Nutter.
mcalvert39
Member #: 442
Manchester
Hey guys sorry for reopening an old thread and all.. but i have a question.
If the block is pocketed for a 1275 head is it then still possible to use a 998 head? Or do i HAVE to use a 1275 setup from then on?
evolotion
Member #: 83
Glasgow, Scotland
nope you can use a 998 head, just your compresion ratio will be a bit lower and chamber shape will be less than optimal. but it will run.
Denis O'Brien.
