Home > General Chat > valve guide setting tool and reamers.
turbo hogster
Member #: 178
stowmaket suffolk
had joey email me regarding the above.
so thought i will set up my lathe again and make some.
so if anyone is intersted here are the prices for these little but effective setting tools.
14.2mm standard hieght £5 each
13.7 mm for high lift £5 or any height you chose.
9/32 reamer £12 each
postage £2.50.
just pm me and send cheque to Mrs T greeves, 127 stowupland road, stowmaket, suffolk, ip14 5ap.
regards the turbo hogster
and have a great xmas.
i bought one last year from him, and glade i did, makes the guides easy to replace and keeps them spot on in height.
What reamer is it hoggy? adjustable?
i only ask, as minispares seem to think the valves ive ordered have a 7.05mm stem...
would the highlift one not do both? or is it quite important to have the guides up high?
cheers
Joe
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
I don't know very much about replacing guides, but as my machine shop carge a little fortune for this job, it's interesting me,
what about the difference between high lifts and std height?
what about seat cutting tool?
thanks
fab
fab summed up my questions precisely
and just to check, is that supposed to be be Mr or Mrs T Greeves??
Edited by Nic on 13th Dec, 2006.
The Mrs Nic. *wink*
slater
Member #: 1291
Suffolk / Birmingham
For a high lift cam you push them in the head further so theres more clearance between the top of the guide and the retainer at full lift
The further you push them in the more guid you have sticking out into the port which obviously isnt ideal
If you replace guides then the seats need re cutting yes? or atleast they do most of the time when i do it.
turbo hogster
Member #: 178
stowmaket suffolk
i have found over the years if you use say a 276 type cam with 1.5 rockers the retainer just catchers the oil seal and ripping it apart on the inlets, buy sitting them further down buy .5mm it misses.
yes the first time you fit new guides from the factory ones you need the seats recut but once you have done this then evry time you refit new guides then they just need a lap in as when the oringinal ones are fitted they are blanks and are drilled reamed and seat cut all in one action and most are not central, but when you fit after market guides they are central so the seats need recutting for the new guides but after the first recut then just e relap should do.
yes the higher lift will do but i can make it any height you like it not a problem.
stay clearof adjustable reamers of that size if you can as they are a pain to use as they are so small and delicate as willy will tell you.
on the mr and mrs thing all cheque goes into the wifes savings account as she doesnt pay tax ( i should have been an accountant).
turbo hogster
Member #: 178
stowmaket suffolk
9/32 is 7.31mm if thats any help.
for iron guides there rarely need reaming but the bronze ones do as they swell when inserted, but personaly i prefer bronze ones as the iron ones ware out to quickly.
fab, just drift out the old guids and use turbo hogsters guid locaters and then ream the guids out
this is excellent hoggi place your order Please fab,
this will give consistent results time after time.......... .......... ........... ......
my orders in now!
cos ...... my eye sights going....lol *laughing*
Edited by BENROSS on 14th Dec, 2006.
fab
Member #: 100
Paris\' suburb
advise catched!
My experience is that if you use stainless valves with bronze guides. The valves wear. If you use chrome stemmed valves and iron guides, the guides wear.
As I replace guides myself, I find it cheaper to use iron guides and let the valves survive *wink*
The valves and guides in the A+ heads are usually in VERY GOOD condition. I don't think I've ever binned an A+ valve due to stem wear. They're EXCELLENT in the wear department however not really up to the job in the flow. Of course back-cutting does help:
Oh btw.. I bought Hogsters kit years ago :)
having never done this before, will the 9/32 be fine for my application, or should i look for one matched to my valve stem thickness?
sorry about all the questions
joe
turbo hogster
Member #: 178
stowmaket suffolk
i would find out the definite sixe of the stems, all the ones ive used are 9/32 stems , well the clearance reamer is anyway, standard and rimflows plus minispares race valves all seem to be of standard size.
cheques in the post
Hoggy,
do you still do the reamers?
skolawn
Member #: 69
Coventry
Still doing these??
I'll tell him to have a look on here and get back to you.
turbo hogster
Member #: 178
stowmaket suffolk
blimy i aint been on here for years, well my supplier of the decent ones has gone abit awol but can see if i can get some more if there is a good quality one, trouble is there is some cheep chinese cr@p out there. ive missed out on about 4 gearbox rebuilds aswell lol ooopppsssss and cheers matty
Rammie2000
Member #: 10190
belgium
sooooo........... these still get made.............
have to do the job myself since the machine shops here ask around 250 and 350 for new guides and reaming.........
TurboDave16V
I can get in the reamers if you’re struggling to locate some
Rammie2000
Member #: 10190
belgium
reamers is not so much of a problem. its the setting tool that i am most interested in ( unless the reamer is better than these here https://www.dormershop.nl/webshop/ruimers/h...rmer-b100.html)
