Page: |
Home > A-Series EFI / Injection > Ignition Options, MSII & Siamesed Port Code | |||||||
5th Dec, 2006 at 08:58:17am
An issue has arisen that anyone considering the Siamesed Port Code should be aware of.
Edited by Paul S on 5th Dec, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5th Dec, 2006 at 12:30:50pm
Actually, while it's true that there has been quite a bit of talk about burnt VB921s (ignition driver transistor), I wouldn't say that there has been limited success. It's only that you hear more about the failures that the successes.
5th Dec, 2006 at 12:35:44pm
Question, maybe a stupid one .....
5th Dec, 2006 at 12:58:49pm
Roger,
11046 Posts Member #: 965 Post Whore Preston On The Brook |
5th Dec, 2006 at 07:19:19pm
VEMS is looking more and more attractive
5th Dec, 2006 at 08:17:12pm
"Most important bits left out"???? What whould they be then, have I missed something????
23 Posts Member #: 1089 Member |
8th Dec, 2006 at 11:03:51am
I am a noob to this Megasquirt etc, how exactly does the 'code' solve the siamesed $1M question? Is it using 1 or 2 injectors per port? What sort of dollar difference is an MS compared to a Motec M4pro or equivalent? Is there any light at the end of the tunnel for EFI 5-porter on a budget?
First 5-port EFI turbo in the world (built 1997, running in 1998) |
8th Dec, 2006 at 12:16:59pm
Megasquirt is universal too. In fact there is specific code to do most things so maybe more adaptable than Motec. Price difference is huge, MS much much cheaper than Motec even if you buy it prebuilt. Every day is a school day ...........
8th Dec, 2006 at 12:33:26pm
The cost of the Motec in Australia is quite cheap I reckon for the adaptablilty. I can run any sensor or ignition system, crank angle and sync combo either hall or magnetic....
Edited by DOZ on 8th Dec, 2006. First 5-port EFI turbo in the world (built 1997, running in 1998) |
8th Dec, 2006 at 07:48:21pm
It is a code to fire the injectors once every 180-crank degrees, but with an 'advance table' such that the start of injecton event varies.
8th Dec, 2006 at 11:49:36pm
Thanks Dave, that's what I thought, although reading my previous post it's probably not that clear (even I'm confused, it was late last night here in Oz and a few ales had their obvious effect).
Page: |
