Page: |
Home > General Chat > Sectioned 1275 Engine Block | |||||||
11046 Posts Member #: 965 Post Whore Preston On The Brook |
26th Nov, 2006 at 11:04:09pm
An old STD bore block I had sectioned. It had spun a bearing and damaged the center bearing housing so not worth saving.
Edited by Sprocket on 16th Oct, 2007. On 26th Oct, 2004 TurboDave16v said:
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
26th Nov, 2006 at 11:11:55pm
good work, and yes one of the holes is very close to the bore wall! nice to see what we can't normaly. Best 1/4 mile 13.2 seconds @116 mph
26th Nov, 2006 at 11:15:17pm
What the fooks that bemt bit of tin doing between 2&3!! or is it 3&4... On 28th Aug, 2011 Kean said:
26th Nov, 2006 at 11:17:41pm
yes looks a bit weird does that! Best 1/4 mile 13.2 seconds @116 mph
26th Nov, 2006 at 11:20:25pm
apparently those are used to tie in the cores when casting. They are in every block. Visard also mentions these. When i had the 74mm block bored, true to Visards word, you could see a difference in clour of metal where this had been exposed as it were. It looks like on this block it may be an issue on big overbores as i can see where the metals havent quite moulded together Edited by Sprocket on 26th Nov, 2006. On 26th Oct, 2004 TurboDave16v said:
3588 Posts Member #: 655 Post Whore Northern Ireland |
26th Nov, 2006 at 11:40:59pm
Given thats all solid cast iron....they look pretty thick to me ???
Site Admin 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
26th Nov, 2006 at 11:46:37pm
Thanks for sharing your results with us Colin! good work! Team www.sheepspeed.com Racing
6274 Posts Member #: 509 Post Whore Isle of Man |
26th Nov, 2006 at 11:58:54pm
on that last pic, look at all that sediment/rust at the bottom of the jacket, i just hope that down there away from the combustion it doesnt hinder cooling too much.
27th Nov, 2006 at 12:10:18am
Great Stuff Colin!
6745 Posts Member #: 828 Post Whore uranus |
27th Nov, 2006 at 07:19:03am
those are some fascinating pictures ,thank you colin . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1497 Posts Member #: 100 Parisien Turbo Expert Paris\' suburb |
27th Nov, 2006 at 10:29:45am
As Said,
138 Posts Member #: 138 Advanced Member |
27th Nov, 2006 at 10:46:21am
Mmmm that is INTERESTING. i suscept those metal 'sheet' between bores, would affect the cooling around the block, by those limiting the flow of coolant.
27th Nov, 2006 at 10:51:06am
1425 Posts Member #: 690 Post Whore Norfolk |
27th Nov, 2006 at 11:37:55am
good stuff colin - the old A looks very different from the inside out! - thanks
If Carling made Mini engines
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
27th Nov, 2006 at 12:47:56pm
great pics, thanks for sharing them!
27th Nov, 2006 at 08:18:15pm
Thanks for the replies people. I my self was curious to see the inside. The pics in TBASE dont depict what you can see in real life.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
27th Nov, 2006 at 08:23:45pm
This may be bollocks, but surely those protruding bits of tin will AID cooling by giving more surface area for water to contact and transfer heat away from the block?????
27th Nov, 2006 at 08:30:26pm
well i be honest and say i dont think it matters at all. The majority of heat is in the combustion chamber, so its the underside of the dack and the head that needs the surface area. Its in these areas that steam pockets build and reduce the conduction of heat to the coolant, resulting in overheating of the combustion chamber.
27th Nov, 2006 at 09:12:25pm
Engine number 12HC14AA and apparently MG Metro 1984 onwards, however, it was not an MG metro cam that cam out, but then the engine had been rebuilt. On 26th Oct, 2004 TurboDave16v said:
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
27th Nov, 2006 at 09:16:20pm
top stuff
27th Nov, 2006 at 11:09:31pm
On 27th of Nov, 2006 at 08:30pm Mini Sprocket said:
well i be honest and say i dont think it matters at all. The majority of heat is in the combustion chamber, so its the underside of the dack and the head that needs the surface area. Its in these areas that steam pockets build and reduce the conduction of heat to the coolant, resulting in overheating of the combustion chamber. Having said that and thinking while im typing, there is not contact of the deck/bore between the cylinders and fron what i have seen of melted pistons it seems to be either #2 or #3 and always across the pins, where the heat would be the highest. There may be some theory to your bollocks Tom!!! Anybody ever had the combustion chamber and piston crown ceramic coated or similar ?? I guess you could do the entire exhaust port too. That should seriously reduce heat dumped into the cooling system, as well as increase heat dumped into the turbocharger, which in theory, should be a good thing. 9.85 @ 145mph
28th Nov, 2006 at 07:29:17am
On 27th of Nov, 2006 at 08:18pm Mini Sprocket said:
As for the 'sediment' at the bottom of the coolant gallery, I dont believe this to be the case. It seems to me to be poor casting, its solid and is shiney when scratched. Its a big restriction. Nail head etc.. If this is the result of pants casting, there maybe something to it in the cooling stakes, particularly if not all blocks are that bad! I've seen the future and tbh its Pie
4th Dec, 2006 at 07:07:59pm
I just bunged a stant high pressure cap on my car (20psi) as it was hanging around,
4626 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
4th Dec, 2006 at 10:25:55pm
On 4th of Dec, 2006 at 07:07pm mini13 said:
is anyone else running higher pressure rad caps? Yep. |
5th Dec, 2006 at 08:55:06am
it will in the summwer thats for sure, i need a 74 thermo plus a extra rad.
Page: |
