Page: |
Home > A-Series EFI / Injection > Sequencial injection idea... | |||||||
4559 Posts Member #: 786 Post Whore Bermingum |
10th Nov, 2006 at 09:28:45pm
11th Nov, 2006 at 10:12:15am
That's a good idea.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
11th Nov, 2006 at 01:11:14pm
Not being funny but if this is such a good idea, why did Rover not do it? and spend shed loads of money on developing sequential timed injection.
11th Nov, 2006 at 01:34:02pm
Edited by Bat on 11th Nov, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
11 Posts Member #: 754 Member |
5th Mar, 2007 at 08:55:45am
What cam do You recommend with turbo and sequencial injection?
5th Mar, 2007 at 10:04:23am
62 Posts Member #: 1515 Advanced Member |
5th Mar, 2007 at 11:01:58am
4 injectors is a good idea. The problem is that most affordable aftermarket ECUs don't have 4 injector drivers. The Emerald M3D sequencial does and some of the MOTECs (not checked the latest OMEX).
5th Mar, 2007 at 12:52:37pm
Bat, what you suggest may be possible to impliment but not with MS2 for the reason Bill states. Staged injectors however can get over the duty cycle problem as you could keep the normal injectors to work with idle and then have others for the extra fuel when required.
5th Mar, 2007 at 12:53:27pm
As far as cams are concerned it'll be teh same cam as you'd normally use with a carb as quite simply there isn't much else avaialble ... that may change though if injected turbo becomes the norm. Every day is a school day ...........
5th Mar, 2007 at 02:46:05pm
Hello!
5th Mar, 2007 at 03:09:19pm
Tcc - Size of injectors doesn't account for everything - a 900cc injector that takes 1.6ms to open for example, along with erratic control is pretty naff.
5th Mar, 2007 at 03:32:13pm
Dave, as you say if the opening time is very large trying to inject only on an open valve (full sequential) becomes very difficult. However, with the semi-sequential once per rev injection then the opening time is meaningless because you have plenty of time between pulses.
5th Mar, 2007 at 07:18:57pm
Jean ...... don't tempt me away from my initial plan ... that will be a big enough challenge to get running well .... fully trimmed, fully sequential to come later ...... Now how will we fit them all in?!?!?!?! Every day is a school day ...........
7th Mar, 2007 at 05:00:53am
Dave, as You know about 160 kW needs about 1350 lbs/min injector at 25 duty. So it has to be big.
7th Mar, 2007 at 09:26:13am
How did you work that out? I only get 480lb/min |
7th Mar, 2007 at 12:23:04pm
215BHP is quite a few bananas but I'm sure you don't need 1350lbs/min to achieve it, even with just two injectors Every day is a school day ...........
7th Mar, 2007 at 03:27:34pm
First of all, you're mixing 2 different units for injector flow rating. It's either lbs/hr or cc/min. With 1350 lbs/min, you'd need a tanker connected to your car to cover any reasonable distance :)
7th Mar, 2007 at 03:47:21pm
Hi! Yes, my mistake (where the hell I get those lbs)? I mean 1350cc/min ofcourse. Is it only true that I cant inject only when one intake is open? This means duty cycle 25?ŽAnd 215 hp is big power!
7th Mar, 2007 at 05:02:45pm
duty is measured over 360 crank degrees, hence a valve is open a little over 180-(crank) degrees, so it's around the 50%, not 25%. On 17th Nov, 2014 Tom Fenton said:
7th Mar, 2007 at 05:55:43pm
Hello!
Page: |
