Page: |
Home > Technical Chat > Camshaft spec database ? | |||||||
3588 Posts Member #: 655 Post Whore Northern Ireland |
19th Sep, 2006 at 10:38:18pm
Anyone have any listings of cam specs that people are using with their turbo setups, and also what they think of them ? 9.85 @ 145mph
19th Sep, 2006 at 10:45:03pm
The figures are definately somewhere on this forum for the (gen1) phase 2 cam from avonbar, aswell as the 'current' ph2 cam.
19th Sep, 2006 at 10:54:16pm
When I first built mine, naturally I used the std cam. As soon as I found what I trusted to be a genuine MG Metro cam, I fitted it, along with the 1.5 rockers.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
21st Sep, 2006 at 12:41:04pm
I'd say that turbo minis generally could use a bit more exhaust lift/duration. I'd like to know a lot more than I do about timing for turbo engines but I think you want the exhaust valve open as early as possible without sapping power. I'm a big advocate for cams which have longer durations of the exhaust rather than lift. (Piper tend to make the latter, kent the former) BL also tended to bias towards the exhaust, IMO this is better. I've played around with all sorts of cams in my engines and reckon the MG is good, the Kent series 266/76 look good and I would have thought the Ph 2 was just what the doctor ordered. Curious to know why it wasn't so good. I'm throwing my piper 270 out and going to fit a Ph2. I can only assume that the large exhaust "area" somehow stifles it at low duty. I'm going to use a Ph 2 in my supercharged engine (12PSI) and if it isn't the best cam for the job, I'll eat my hair.
Bugger off, I'm getting there. |
21st Sep, 2006 at 06:46:14pm
Ive heard brief mention that some of the turbo spec cams here have much longer exhaust duration than the inlet.
Edited by stevieturbo on 21st Sep, 2006. 9.85 @ 145mph
11046 Posts Member #: 965 Post Whore Preston On The Brook |
21st Sep, 2006 at 07:11:04pm
Peter recons the Kent 274 cam for the injection would be a good bet in a forced indution aplication. Its also available in scatter pattern. Pretty standard inlet duration with more exhaust. Im running one NA at the mo, cant say much about it as ive gone to 1400 and fitted a 3.76 diff at the same time so cant tell whats doing what. It does pull hard from around 2000 in fourth. On 26th Oct, 2004 TurboDave16v said:
2521 Posts Member #: 417 Post Whore Swindon |
21st Sep, 2006 at 07:39:51pm
I got a kent 276 in,won't pull at all below 2k,takes of like a rocket once 4k is passed
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
21st Sep, 2006 at 08:48:16pm
http://www.mlmotorsport.com/forums/viewtopic.php?t=11
21st Sep, 2006 at 09:47:53pm
On 21/09/2006 19:39:51 Dangerous said:
I got a kent 276 in,won't pull at all below 2k,takes of like a rocket once 4k is passed So bit hard to drive in traffic with 3.1diff and 185/55/13's Kents 274SP cam spec http://www.kentcams.com/product/prodDets.a...95&ModEngID=429 Kents 276 cam spec http://www.kentcams.com/product/prodDets.a...99&ModEngID=429 On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 09:54:31pm
Interesting....
21st Sep, 2006 at 10:24:26pm
duno much about this stuffbut id have thought that NA requires more intake to get as much mixture into the cylinder as poss. Forced induction doesnt need a lot of inlet because the charge if forced in. Increasing exhaust on forced, releases the greater volume of gasses produced, more efficiently.
22nd Sep, 2006 at 01:52:35am
A lot is down to the relationship between intake/exhaust, rather than looking at one of them.
23rd Sep, 2006 at 05:27:52pm
http://www.turbominis.co.uk/iain/up/cam_data001.gif
23rd Sep, 2006 at 06:38:56pm
Wouldnt that cam have horrendous amounts of overlap ???
Edited by stevieturbo on 23rd Sep, 2006. 9.85 @ 145mph
36 Posts Member #: 262 Member Netherlands |
24th Sep, 2006 at 12:19:56pm
Here some more camshaft data: http://members.home.nl/jeroen.kuijf/techno...nokkenassen.xls Op de bank beleef je geen avonturen |
24th Sep, 2006 at 02:37:11pm
Some very useful info there... 9.85 @ 145mph
4th Oct, 2006 at 09:13:55am
I have currently a Phase 2 cam in my engine with 1,5 rockers. It pulls strong from about 1500-2000 rpm but the big difference to typical engines is the size. I have a 1380 engine which tames the cam quite a bit. The first cam that got kind of destroyed was from Stuart Gurr back in mid 90s and I dialed the profile after it was removed from the engine (there was actually one in and one ex lobe that were still looking like cam lobes). It was surprisingly similar to MD286 and ran very strong. I had to raise the boost to get anywhere close to RR figures with Ph2.
4th Oct, 2006 at 05:35:37pm
I'll defo be going for a custom grind....either that, or just stick with the SW5 I currently have. 9.85 @ 145mph
5th Oct, 2006 at 08:00:18pm
I'm not sure about the longer inlet than exhaust. I suppose if you have a massive valve, massive ports and massive velocity, the ramming effect may be more important than the weeny bit of residual you have from a shorter exhaust. Bearing in mind things like the supersprint cam have huge durations anyway and so you could be looking at exhaust pressure effects (shockwaves) adding to the picture. I'd also be aware of the compressed charge having a greater density, resonant properties. Not sure about this and I had a think about it a while ago, did some calculations, not really relevant for our 5 porters but if you did want to employ resonance (take notice of it anyway) it would be at a considerably higher frequency. Again, port sizes being more important.....I'd say that the inertial ramming effect would be less as there is significantly less dP between atmospheric and valve closed rather than boost pressure vs valve closed with ramming. So, on that note, I would have thought that incresed duration may allow the lot to get up to speed but I suppose the overlap would start doing interesting things to it. Looking at the valve sizes and the ports, I'd say that boosting an engine to say 1 bar is looking like giving you a realistic exhaust flow of a 2L N/A engine. Since the ports are weeny, you're looking at getting some huge life, some huge duration on that just to make it towards the ideal. This may compromise your inlet timing by having to shuffle it a bit. I reckon it would be interesting to try a Ph2, a 274spi and a Ph2 against each other and see which is the best. All on 1.3 rockers. My money is on the Ph2, followed by the 274 and bringing up the rear the SW5.
167 Posts Member #: 11091 Advanced Member |
18th Jan, 2017 at 09:57:39am
Updated pic of the med t3 camshaft |
Page: |
