Home > How To > Fuel pump
This must be mounted as low as possible. Some people go as far to mount it on the rear subby but mines low down on the rear seat. It does make it more nosiey inside however, especially since ive got no rear seat fitted. Use anti-vibration mounts to help reduce this.
Its a good idea to fit an inline filter between the tank and the pump (not shown as i haven got one fitted at the moment). It needs 10mm tails to match the 10mm pipe between the pump and tank.
TurboDave16V
errr - is that plumbed in right?
The outlet end of the pump is the one nearest the connections. the way that looks is it's dragging fuel from the std outlet of the tank and into the outlet of the pump???? *surprised* *surprised* *surprised*
Or is the pump outlet just going through the floor in the normal place, and you have a different pickup point (10mm tube) from the tank?
D
Edited by TurboDave16V on 24th Jul, 2003.
The outlet of the tank its near the boot opening just out of shot *happy* the outlet from the pump just dips down near where the old outlet is blanked off and through the floor.
sorry for the confusion!
Anyway its all changed now. ive modded the original tank outlet to 10mm so im picking up from there. *happy*
