Home > Help Needed / General Tech Chat > Bimmer Twinky Cam Swap
Any one want to swap some RS cams for some LT cams?
I know this may be in the wrong section but feel i will get a better response on this one??
MS
TurboDave16V
You have RS ones - or LT ones?
I have RS, Sorry
Originaly a K100RS, they never did a four valve K100LT
Edited by Sprocket on 30th Jul, 2006.
jukka
Member #: 60
Forgotten more than most ever know
What is the actual difference between the two ?
I can check which ones I have, send me e-mail directly to jukka.harkola@netti.fi
johnK
Member #: 690
Norfolk
Jukka - K1100 are around 256 degs and 8.8mm lift, Rs are around 284 degs lift and 9.8mm lift
JK
If Carling made Mini engines
Thanks people, the deal has been done, thanks to Antman*wink*
