Page: |
Home > A-Series EFI / Injection > SPI gearbox transfer case. | |||||||
138 Posts Member #: 138 Advanced Member |
8th Jul, 2006 at 11:51:01pm
My mini got SPI transfer case, it has a hole for flywheel sensor. come with a sensor wiring. can i use this to install mega jolt lite instead of using a bracket and toothed damper pully?
2521 Posts Member #: 417 Post Whore Swindon |
9th Jul, 2006 at 12:52:17am
I don't think the spi flywheel has the right number of teeth
11046 Posts Member #: 965 Post Whore Preston On The Brook |
9th Jul, 2006 at 12:52:46am
Depends on the fly wheel you use. It needs to be, idealy the later SPi wheel that has the reluctor which is just pressed in, the earlier ones also have two rivots to retain it and can be a bit more difficult.
Edited by Sprocket on 9th Jul, 2006. On 26th Oct, 2004 TurboDave16v said:
Page: |
