| Home > Help Needed / General Tech Chat > Compression ratios and their effect on turbo'd engines | |||||||
5th Aug, 2010 at 09:13:17pm
I'm hoping someone on here will be able to help....
6th Aug, 2010 at 12:16:40am
yes that's the right idea.
6th Aug, 2010 at 09:55:04am
Detonation is not caused directly by boost but the associated increase in the intake air temperature due to the compression within the turbo/supercharger.
857 Posts Member #: 1778 Post Whore Northants |
6th Aug, 2010 at 10:01:09am
Might be worth adding that certain metals are also better at heat dissipation (think that's the right word) and allow you to run more boost at a certain CR. |
6th Aug, 2010 at 10:27:01am
or you could increase the RON of the fuel. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
6th Aug, 2010 at 10:35:36am
Or, technically use water injection although I don't know if anyone here has used it with good results. |
6th Aug, 2010 at 12:24:50pm
it tends to bring up alot of anti water injection comments but those using it are getting good results there is a couple of extreemely good threads on it Yes i moved to the darkside |
6th Aug, 2010 at 01:45:36pm
I agree, i personally think that you should use a better intercooler or drop the CR to do it properly.
2496 Posts Member #: 1954 Post Whore Luton Bedfordshire |
6th Aug, 2010 at 02:55:23pm
http://www.rbracing-rsr.com/compression.htm
Own the day
6th Aug, 2010 at 03:08:47pm
i agree sturgie aswell
6th Aug, 2010 at 08:44:52pm
Great! So either I take some meat out of the chambers and run 15psi - what power would inend up with? Or I run 8 psi and a massive intercooler and hope! On 7th Nov, 2011 apbellamy said:
6th Aug, 2010 at 08:52:55pm
Thanks for the replies, all very interesting. Its all making sense now, I have a spare engine so I might experiment a little!
7th Aug, 2010 at 09:39:39am
I found this and thought you all might find it interesting
7th Aug, 2010 at 10:36:15am
Or you could use this one http://www.not2fast.com/turbo/glossary/turbo_calc.shtml and do everything at once on one spread sheet On 26th Oct, 2004 TurboDave16v said:
