Page: |
Home > For Sale > Turbo dizzy | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
26th Jan, 2009 at 12:05:03pm
MG metro Turbo electonic dizzy good working order removed from running engine, Stamped: AUU1081 2003 42628K 0288
Edited by retroracer1380 on 3rd Feb, 2009. |
26th Jan, 2009 at 01:44:29pm
The top two items are from a 1300(1275cc) Montego/Maestro, both normally asperated cars.
26th Jan, 2009 at 02:54:04pm
The Top item you would have to drill a hole in the Mating Surface for the float bowl pressure feed. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jan, 2009 at 02:57:54pm
On 26th Jan, 2009 MikeRace said:
The Top item you would have to drill a hole in the Mating Surface for the float bowl pressure feed. And sort out some kind of restricter. JF On 21st Jan, 2011 fastcarl said:
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
31st Jan, 2009 at 11:02:09pm
I had the top item fitted on my van for a while as with suitable float bowl pressurisation hole drilled and modded for intercooler inlet in a similar entry position but have had BIG problems settting the fuelling up, even with the obligatory 37 mm dia hole restrictor plate. I would only fit this type of plenum to NA. Forget forced induction, it's just not worth the effort to get it to work. Would make a great 'Ram Air' NA plenum.
1st Feb, 2009 at 12:29:24pm
Cheers all for identification, will change description, so as not to mislead |
3rd Feb, 2009 at 02:33:14pm
Anyone for the turbo dizzy? |
![]() 16 Posts Member #: 2095 Member Dongen Netherlands |
13th May, 2009 at 10:51:21pm
do you still have it? the dizzy? |
Page: |
