Home > Show Us Yours! > Hull mini turbo build
Jimmyful
Member #: 9865
Just a random question, how reliable is a well Built metro turbo? Can they be used as an every day car?
yep, I use my turbo everyday
Joe you have a metro??
*tongue*
no, same here, i use mine as a daily....
Jimmyful
Member #: 9865
That's ace, thats what I'll be doing over summer that's all.
bennyy
Member #: 9037
Doncaster, yorkshire
If driven normally ie off boost the majority of the time I can't see it being any less reliable than an na 1275. In mine just keeping up with the flow of traffic, changing gear at 3k rpm, it would plod around all day, but I had 18psi at the ready so didn't do much tootling around.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
The metro turbo engine in standard form is good for 100k miles.
Jimmyful
Member #: 9865
That's music to my ears a mate of mine seems to think I'm going to have nothing but problems, I'm just after a solid engine that I can drive every day and on track days I can up the boost and have fun*smiley*
Jimmyful
Member #: 9865
Finally got the subframe clean and had some metal paint kicking around so painted it.
Jimmyful
Member #: 9865
*smiley*
Edited by Jimmyful on 12th Apr, 2012.
Jimmyful
Member #: 9865
Just waiting on my pollybush kit.
Jimmyful
Member #: 9865
Now I know this may get asked a lot and I also am aware there is a search button however.
I have left the wireing in, standard 1275 can I use this once all the turbo stuff is fitted? I have done some research and have found out I don't need the ecu.
Thanks
c2_mad
Member #: 4215
yes you can...
Jimmyful
Member #: 9865
Poly flex kit has arrived. Need to dig the rubber rings out the bin for the top arms has they don't come with the kit.
Jimmyful
Member #: 9865
wez
Member #: 9271
Stoke on Trent
how come you've got all the front subframe mounts when you've got a removable front end? surely solid mounts would be safer?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Jimmyful
Member #: 9865
Humm I just asked for the kit for the front subframe what's not needed? Thanks James
jamie@thefatgarage
Member #: 9345
Sheffield
Solid mounts are optional, I use poly ones.
Jimmyful
Member #: 9865
Ahh I see are they the solid rubber mounts that bolt underneath the steering rack? The poly ones have metal inserts I hope they wouldn't make them if they were unsafe.
Jimmyful
Member #: 9865
Need to raid the bin for the rubber rings that go on these.
Jimmyful
Member #: 9865
Oh took a wheel arch to get it paint matched today got cellulose, will spray bulkhead on weekend and get subframe done just need ball joints & track rod ends may aswell replace them.
wez
Member #: 9271
Stoke on Trent
im not saying they are unsafe, not on a standard front mini, but on a mini with a removable front end i wouldn't use them.
does any one else? as your the first person ive ever heard of to use anything other than solid, fair enough some people argue about weather to use brace bars or not, but using soft mounts?
Jimmyful
Member #: 9865
I can't really see them making too much difference I have the brace bars and there's the two big bolts holding them in, I still have the solid ones but I can't see them barring much force (with the brace bars & other fixings) im not confident using them if anyone else uses them let me know ? Taa
i have seen many minis at shows and stuff with a flip/ removable front and std rubber mounts on the front subframe,
Jimmyful
Member #: 9865
Jimmyful
Member #: 9865
Made some progress today here's what iv been up too.
Users viewing this thread: none. (+ 3 Guests) <- Prev   Next ->
