Home > General Chat > your 330ft times(and 1.8th and 1/4 an just about everyfink!)UPDATED 19/8/15
thanks ron ,i stuck in some i found,but no idea if theyre the best ones.
So ally 7 or steel 7 port or an old school 8 port?
On 29th Aug, 2011 paul wiginton said:
K heads arent an option for me Paul
On 29th Aug, 2011 robert said:
On 29th Aug, 2011 matty said:
Robert, as much as I'd like for mine to be 540kgs, I reckon its got to be closer to 560-570kg, as its nowhere near as light as Nics!
ooops sorry matty ,i'll change it , i thought yours was lighter than nics now .
Cheers Robert. Mines going on another diet this year though. With my new TIG set im hoping to make most things out of ally. *happy*
I might have some bits for you to weld Matty
If you want weights, then the TT2-7P is 550kgs and the Sprint is 720kgs, I weight 70kgs.
what was the escort oops sorry sprints 1/4 wil? i think i must have missed it .oh ,wil im trying to stick to treaded tyres for a good comparison .do you have any 048 run with it at all?
Edited by robert on 29th Aug, 2011.
The Sprint only ran the normal road tyres.
1/4 mile times as follows
TT2 - 13.059 @ 105.15 (this is sat on the rev limiter for the last 200 yards or so
Sprint - 16.292 @ 83.94
oops no i meant on the tt2 ,any rd tyre runs ?
No, might have been interesting though.
andy and johns skip added to the 1/4 mile runs now.
On 29th Aug, 2011 Star Mag said:
I will get some numbers later in the week, slips are down the workshop and I've not had any motivation to go down for a while :(
any luck aaron ?
Star Mag
Member #: 375
Leicestershire
I will be down the workshop this week Robert. Had a smash in the daily so have been abit worse for wear the last couple of weeks! On the mend now and hopefully in the workshop this week!
EDIT: I'm a sick boy.
Edited by John on 6th Sep, 2011.
I'll dig my 1/4 tickets out for the van.
hope you feel fine soon aaron ,and thanks john that would be great . im hoping to make some interesting graphs from the data for everyone to look at .
I think the 60ft times were better last year as we had better tyres.
perhaps this would be a good thread to draw david vizards attention to?
ediitted the list to add my latest pb.
turbosprite
Member #: 9668
Nuneaton
Somewhat late here, but hey...
Timing tickets from Santa Pod RWYB 11/6/1994. My car (AH Sprite - so RWD) running standard Metro setup but with gas-flowed head (standard valves), 9:1 compression, 9psi boost, no intercooler, slipping (standard) clutch, open diff, no tramp bars, Pirelli P5's. Car weighed 760kg, me 70kg. Best was my second run:
Reaction: .894
60ft: 2.460
1/8 9.829s, 73.07mph
1/4 15.188, 90.18mph
I later got a higher terminal speed of 92.18 - which from the formula in Vizard's book (and guessing the fudge factors) gave an estimated 130bhp.
1971 Austin (Healey) Sprite - running turbocharged since 1993
My Car thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=448825
130 bhp on 9psi with a pretty much standard engine, sounds optimistic.
au contraire andy , with a good head , its feasable , the slipping a standard turbo clutch is correct for around 130bhp ..maybe it was a very cold day .
been a while since seeing this thread nice lists there Robert i may be getting a power figure for mine after chrimbo before some parts come off it
turbosprite
Member #: 9668
Nuneaton
I would quite openly admit that the 130bhp sounded good - again this was only a calculated value from my best terminal speed. I put the car in the weighbridge at work the next day. Vizards book (1st edition of tuning A-Series) gives a formula, including fudge factors for different cars. As a blown Sprite is not included, I made an educated guess from the Spridget, Metro & Metro Turbo figures. Could easily be 10% wrong. And don't forget this is RWD - so not a Mini clutch, but a standard Spridget cover (6.5) with special plate for my Toyota gearbox.
For anyone datalogging.
Phil from Megalog viewer gave me a formula to calculate distance in feet based on speed vs time from datalogs.
Not all strips give a full 1/4 run breakdown, or you could use road testing to compare various split times when you dont have a timing slip.
Ideally it would be undriven wheel speed so no slippage, and a decent logging rate, ie at least 10hz
ahh good point , doh , i had completely forgotten it had a different clutch !
