Page: |
Home > Show Us Yours! > Massive, uneconomical, rusty project | |||||||
288 Posts Member #: 6267 Senior Member Bristol |
20th Oct, 2010 at 11:29:57pm
Thanks for that, it supports what the pictures I have found show. The RH tank stand is just a mirror image of the left. unfortunately what that does mean is that the crease in my tank stand is in completely the wrong place. I suppose I'll try and correct it. |
21st Oct, 2010 at 06:48:37pm
I've got all the welding inside the boot done today, it still doesn't look all that different but I'm not far from fitting the rear panel now.
Edited by Flame Red on 11th Jul, 2017. |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
21st Oct, 2010 at 07:40:46pm
Waits patiently for Sprocket with his picture of the engine mountain... On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
230 Posts Member #: 1131 Senior Member |
24th Oct, 2010 at 09:58:55pm
great project mate |
24th Oct, 2010 at 10:57:38pm
Only a small update, I should have got more done than I have as I've been on holiday for the last week but I've spent a bit too much time going out followed by getting up in the afternoon! I also spent most of today putting my engine and subframe in a shed which was already full, I can't describe how difficult it was. So those are my excuses!
8th Nov, 2010 at 05:58:48pm
I went and got some more panels at the weekend. I've got Mk1 inner A panels, I can already see that they are not going to be very easy to fit. I also have a pair of lightweight doors converted for sliding windows and reinforced for external hinges. I've got a genuine doorstep due to the issues I had with the pattern panel. I got all the other bits I hadn't even thought of initially such as fuel tank bracket, earth strap nut retainer and wiring tags. I have also decided to fit a set of Cooper boot board brackets.
8th Nov, 2010 at 06:12:41pm
My rear quarter didn't line up with new the arch closing panel. It clamped up OK though. My problems are at the B post, massive gap making for a bent panel... On 11th Feb, 2015 robert said:
9th Nov, 2010 at 06:56:04pm
I've spent all day on this today, I've got the quarter panel on. After cutting a bit out the closing panel it fitted quite well.
9th Nov, 2010 at 08:31:59pm
9th Nov, 2010 at 08:51:17pm
On 9th Nov, 2010 apbellamy said:
Looks good. Is that a genuine quarter? Yes, it's genuine. Since the doorstep I've decided to only use heritage if possible. |
9th Nov, 2010 at 09:08:35pm
I think after my experience with the hopeless boot floor repair section and the nightmare rear quarter, I'm going to be doing exactly the same!
9th Nov, 2010 at 11:23:05pm
I think I put about 50% more plug welds in than there were spot welds originally, I've ground them all down now so I can't measure them I'm afraid. The ones on the lower curved bit were really difficult to grind down I found, it's a shame it isn't possible to spot weld it. |
Site Admin 9403 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
9th Nov, 2010 at 11:29:54pm
hi Buddy, do you still have the back 1/4's and back panell? do you want to sell them??
10th Nov, 2010 at 08:10:05am
I've got one of these:
10th Nov, 2010 at 08:21:07am
On 9th Nov, 2010 Jimster said:
hi Buddy, do you still have the back 1/4's and back panell? do you want to sell them?? Cheers Jimbo I do and you're welcome to them if you can make any use of them but I must warn you that they have not been removed all that carefully. The passenger side quarter panel is a bodged mess with a new panel lapped over the old, the drivers side is ok at the top but not straight at the bottom. Perhaps if you let me know what you need them for and I'll let you know if they'll be any good. |
10th Nov, 2010 at 09:26:03am
I was thinking of keeping them to replace panels on my autograss mini (when the time comes) Team www.sheepspeed.com Racing
10th Nov, 2010 at 09:45:10am
The only panel which is near complete is the drivers side quarter panel, it also has no rust but the first repair I welded along the bottom is not at all neat, could be fine for what you want it for though. The back panel could not easily be fitted complete as I cut it away from all the seams. There are some quite decent sections which could be used though and it is only really rusty along the bottom. The passenger side quarter panel is not even worth thinking about using.
10th Nov, 2010 at 10:04:08am
if you could get photo's that would be great buddy Team www.sheepspeed.com Racing
10th Nov, 2010 at 10:51:10am
. Edited by Flame Red on 11th Jul, 2017. |
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
10th Nov, 2010 at 12:27:32pm
Thats coming on nicely! I know what you mean about wanting to get on with the front...im fed up of working on the back now. lol
10th Nov, 2010 at 12:29:32pm
cheers for taking the time to show some photo's buddy, but i think your right, I don't think they will be any good to me :(
10th Nov, 2010 at 01:10:05pm
Matty - I've got quite a bit to do on the front, I've got inner wings, A panels, front panel, scuttle, A panel boxing plates and outer wings. I also have inner A panels which are pattern panels and not made to fit a Mk3 so I already know I'm going to have fun trying to fit them, at the moment it seems like the best way to get the hinges in the right place. Again it's all made out of filler or very poor quality repairs. I'd like to think I'm 2/3 of the way through the bodywork now.
10th Nov, 2010 at 02:15:06pm
Ah sounds like you're having to fit exactly the same panels as me then. Looking forward to seeing how well the front end goes. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Nov, 2010 at 04:38:47pm
I've managed to put a few hours in on this over the last couple of days. I had a couple of bits left on the boot floor which needed finishing off, I wasn't sure what to do where the arch, floor and valance closing panel meet, it looked untidy as all the edges were different lengths so I decided to seam weld it.
4304 Posts Member #: 1321 Post Whore Wiltshire |
13th Nov, 2010 at 05:33:55pm
Loving the scrap pile, they'll probably just assume you've cut up a body shell to weight in!
Page: |
