Home > Show Us Yours! > MG Metro Turbo Van
Standard Dash
Diet Dash
Not the most scientific of measuring sticks, but it's good enough as a guide. It had the heater at 7KG *smiley* So with a few other bits and bob's that's 12KG out of it already.
well i have taken a further 1/2 a kilo off the head for it today andy, so add that also buddy
*Clapping*
Better weigh the old exhaust and the T3 too. I bet the new stuff is quite a bit lighter.
bennyy
Member #: 9037
Doncaster, yorkshire
Out of interest lads, without scrolling through 27 or so pages, What sort of spec/boost run we're you using when you made the 153bhp?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
The TM disease is getting bad. I found myself sat in the van last night looking for things to remove.
On top of what we have already lost I've been looking at:-
Bitumen sound deadening pads on the floor
Comfy seats
Door Cards
Extra plastics
Big heavy steel bulkhead to the load bay.
And other silly little things like interior lights etc.
Minispares Stage 3 Head with 28cc chambers
Standard Metro Turbo 20831 Pistons with TotalSeal Piston Rings
ARP Rod Bolts
N/A MG Metro Cam
STD T3 with ported manifold
1:1 SC Drops
STD Helical box with x-pin diff
MR2 Intercooler
Megajolt
Actuator was set at 12.5psi but it spiked to ~15psi at about 4200rpm on the rollers where peak torque was made.
bennyy
Member #: 9037
Cheers, My spec is similar, exept for the mj.
Best thing we ever put on there Benny! Well worth the money.
bennyy
Member #: 9037
Yes I've heard a few say that, may well be next on the list *wink*
Those total seal rings are worth 5% *wink* *happy*
Lots of progress this week *smiley*
Benross has nearly finished the head refurb/upgrade, should be a cracker when it's done.
The block has been stripped and drilled for 11 head studs. That'll be getting dropped into Fast Carl for new cam bearings tomorrow. His oil fed thrusts have done their job well, the thrusts are near on perfect after a load of abuse on the road and drag strip. *happy* The new rotating assembly will be going for balancing tomorrow too.
The new box is just about done, just need to fit the diff.
New exhaust is nearly sorted.
Got the new turbo butchered onto the metro manifold.
Getting there.
Them exhaust mounts look a bit flimsy *wink*
I'm going to clamp it on with your hands and then cut them of at the wrist *wink*
And you've given the game away about the new turbo. *tongue*
That's a different new turbo though...
Fair enough. *happy*
Really looking forward to getting it underway with the new turbo.
oli79
Member #: 8480
Looking good boys, its all coming together, I make it 7/8 weeks to avon so its going to be tight, working on my own minor weight loss at the mo.
And what looks like a gt17? as well, great-going to get beaten by another yellow van as happened at York!
oli
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Should save a bit, you got TM disease bad!!!!!
T-shirt
Pants
Man-bra
Socks
Girdle.....etc.
Lol at Wil
We're away for a week from midweek, then both of work until after the bank holiday. We aim to get the engine built and potentially fitted. Then it's all the little bits that take forever. Should be OK for Avon...
mayoturbo
Member #: 1395
chepstow
What size exhaust tubing are you using? Good progress, I have not touched my metro in ages now
The down pipe is about 2.5" at the turbo end going down to 2 1/8" after the flexi, then 2" all the way to the end.
tadge44
Member #: 2500
Buckinghamshire
I think you need some of my patented washers for the the turbo to manifold studs.
Got an spare Dave?
I should say that I lke the exhaust, but use Mikalor clamps instead of the shit U-bolts.
Interestingly I had a similar exhaust on the original hillclimber we built, and unlike Roberts beastie it was worse on power, couldn't explain it.
