Page: |
Home > Show Us Yours! > Stay classy! 998 turbo | |||||||
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
4th Sep, 2014 at 07:32:27pm
nahh nahh, i blame Shauna
Yes i moved to the darkside
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
4th Sep, 2014 at 07:49:18pm
On 4th Sep, 2014 Shauna said:
NO. Carl tricked me into looking up blue waffle a long time ago and ever since I have had safe search on! I'm loving the innocent young lady act. Don't forget we've met you... On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
1043 Posts Member #: 10424 Post Whore Swansea boyo! |
4th Sep, 2014 at 07:54:08pm
You've met me very briefly! I know what it means now because Carl has told me, whatever he does while I'm away is his own business, I do not need to know!
NO. Carl tricked me into looking up blue waffle a long time ago and ever since I have had safe search on! I'm loving the innocent young lady act. Don't forget we've met you... Anyway, back on topic! They don't die, they just get faster! |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
4th Sep, 2014 at 08:49:24pm
I've been following this whilst working outside haha. Gearbox and transfer case is back on, and I've received the flexible intake pipe today, so I've fitted the air filter to the 2.5" to 2" exhaust adapter (the only thing I could find suitable that wasn't flexible as I can't really bolt to silicone) and the flexi hose to the other end of the filter size adapter. The other end of the flexi pipe slides perfectly over the turbo intake. On 26th Jan, 2012 Tom Fenton said:
882 Posts Member #: 9774 Post Whore Buckinghamshire |
4th Sep, 2014 at 10:39:15pm
Looks good will be nice to see another 998 turbo around, though this must be at least the second that'll be finished before me!!
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
8th Sep, 2014 at 04:30:35pm
Engines in the hole! But sadly minispares did another mess up and gave us the wrong headgasket :(
301 Posts Member #: 10610 Senior Member Wiltshire |
8th Sep, 2014 at 04:57:38pm
What happened to the clutch cover where the starter motor goes in, it looks a bit has broken off? |
8th Sep, 2014 at 05:24:49pm
Yeah it's when my mate tried removing a flywheel when he had that engine, slipped a bit with the lumphammer haha. It's been like it for ages, can't really see it when the starter is on and it's not under stress or anything, more cosmetic than anything On 26th Jan, 2012 Tom Fenton said:
8th Sep, 2014 at 05:28:09pm
Liar, I bet you broke it.
On 8th Sep, 2014 Carlzilla said:
Yeah it's when my mate tried removing a flywheel when he had that engine, slipped a bit with the lumphammer haha. It's been like it for ages, can't really see it when the starter is on and it's not under stress or anything, more cosmetic than anything They don't die, they just get faster! |
8th Sep, 2014 at 06:45:56pm
Ah fair enough |
8th Sep, 2014 at 08:27:25pm
Go and ask hamster, he'll own up to breaking it!
On 8th Sep, 2014 Shauna said:
Liar, I bet you broke it. On 8th Sep, 2014 Carlzilla said: Yeah it's when my mate tried removing a flywheel when he had that engine, slipped a bit with the lumphammer haha. It's been like it for ages, can't really see it when the starter is on and it's not under stress or anything, more cosmetic than anything On 26th Jan, 2012 Tom Fenton said:
8th Sep, 2014 at 08:39:00pm
The bores had a hone mike, wouldn't fit new rings without honing first!
On 4th Sep, 2014 Mike-998 said:
Looks good will be nice to see another 998 turbo around, though this must be at least the second that'll be finished before me!! Quick question though, did you get the bore's de-glazed for the new rings? On 26th Jan, 2012 Tom Fenton said:
28th Sep, 2014 at 10:07:43am
Sorry for not updating this for ages, I'll do a much better update when I've got time during the week! But for those who don't have me or Carl on facebook this happened yesterday! First flick of the key..
6729 Posts Member #: 618 Post Whore Glasgow |
28th Sep, 2014 at 10:56:35am
The videos are coming up private so cant see.
28th Sep, 2014 at 11:56:27am
It's the needle and spring that came with the rebuild kit. Videos should be viewable now! They don't die, they just get faster! |
6745 Posts Member #: 828 Post Whore uranus |
28th Sep, 2014 at 05:07:53pm
excellent sounds nice and tight
28th Sep, 2014 at 05:18:38pm
Any advice for getting it to idle properly? Obviously I would know where to start with an n/a a series with a distributor, but this is a bit new to me with MJ, the turbo isn't yet plumbed up to the plenum either. On 26th Jan, 2012 Tom Fenton said:
28th Sep, 2014 at 05:20:16pm
Just needs a bit of loving to nurse it to the rolling road in the week! We just couldn't believe it started first time, I expected it to take a few turns but he went. Oil pressure came really easily too with no leaks (apart from my massive one!) or water leaks either which is a relief. All that's left is to sort the catch tank, put my dash back together and get it running sweeeeet! It's been a long two months without him and he put up a good old fight but it should be hitting the road towards the end of the week . Massive thanks to everyone for their help too! They don't die, they just get faster! |
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
28th Sep, 2014 at 05:28:42pm
I would finish the pluming first mate, then see if it's the same.
4890 Posts Member #: 1775 Post Whore Chester |
28th Sep, 2014 at 06:27:37pm
good effort... and good luck at the rollers. I run a supercharger and I don't care the TB is on the wrong side.
28th Sep, 2014 at 06:55:06pm
Thanks man! A real shame it didn't make Combe but there's always next year when it's had the paint sorted and the original front seat are back in. Winter is going to be tough on him this year as there's a few areas showing through the paint (just under a year and a half after a respray!), nothing serious of course but he's he got a lovely big scratch in the boot while being parked up which needs attention :(
On 28th Sep, 2014 gr4h4m said:
good effort... and good luck at the rollers. They don't die, they just get faster! |
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
28th Sep, 2014 at 07:24:28pm
Plumb it up. Put a basic safe map on it and shove a BDD in there. Get the idle to about 13.5:1 when its warm that should safely get you to the rollers.
28th Sep, 2014 at 07:36:54pm
sounds well, im gonna guess its running megajolt?
28th Sep, 2014 at 08:13:12pm
Thanks guys! Yeah we are on MJ. John I'll send you Carls on Facebook (: They don't die, they just get faster! |
28th Sep, 2014 at 08:17:18pm
I'll have a look to see if theres a bdd in any of the 3 hif carbs i have, or even if there's already one in the carb. Thanks for the pointers, I'll have a go tomorrow after work! On 26th Jan, 2012 Tom Fenton said:
Page: |
