Page: |
Home > A-Series EFI / Injection > MPI idle valve - on MS3 | |||||||
15th Nov, 2011 at 04:12:39pm
On 15th Nov, 2011 Paul S said:
Blimey, did you know that the MS1 is now over 10 year old technology ! Not fair to compare it with a current product really. And it wasn't even state of the art when it came out. Edited by jbelanger on 15th Nov, 2011. |
15th Nov, 2011 at 05:24:59pm
I did state that when I made my comparison.
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
17th Nov, 2011 at 09:50:00am
Jenvey offer a good selection of parts for idle air control to go with their throttle bodies:
17th Nov, 2011 at 10:10:03am
Good find Paul. that looks fairly simple to retro fit to my s.c. kit if the ecu can control it. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
17th Nov, 2011 at 01:30:42pm
Is that a Stepper, PWM or an on off valve? On 26th Oct, 2004 TurboDave16v said:
17th Nov, 2011 at 01:33:14pm
Looks like a 4-wire stepper to me. Best check with Jenvey first. Edited by Paul S on 17th Nov, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
114 Posts Member #: 9645 Advanced Member South Wales |
18th Nov, 2011 at 08:38:20am
Am I correct in saying that it should be fine to test the 4 wire stepper off the outputs on the Jimstim?
18th Nov, 2011 at 03:02:01pm
If you mean connecting the stepper to the screw terminals on the JimStim and letting the MS drive it then yes it should be fine.
18th Nov, 2011 at 03:04:30pm
Just be careful that you do not fire the plunger across the room :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th Nov, 2011 at 03:11:50pm
Thanks for the advice.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
20th Nov, 2011 at 02:51:19pm
I cable tied mine to a piece of wood and screwed a woodscrew in so the plunger hit it at near maximum travel but before it shot across the room.
![]() 6748 Posts Member #: 828 Post Whore uranus |
20th Nov, 2011 at 03:31:33pm
Blimey, did you know that the MS1 is now over 10 year old technology ! Not fair to compare it with a current product really. And it wasn't even state of the art when it came out. bah !!i shudder to think of whats in the accel dfi ecu i put on the tvr in 1990!! ![]() Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Nov, 2011 at 03:41:02pm
Blimey, did you know that the MS1 is now over 10 year old technology ! Not fair to compare it with a current product really. And it wasn't even state of the art when it came out. bah !!i shudder to think of whats in the accel dfi ecu i put on the tvr in 1990!! ![]() It certainly was more advanced than that: http://www.allpar.com/cars/desoto/electrojector.html. Look a little down the page to see what the electronics look like. Jean |
23rd Nov, 2011 at 06:00:12pm
Blimey, did you know that the MS1 is now over 10 year old technology ! Not fair to compare it with a current product really. And it wasn't even state of the art when it came out. bah !!i shudder to think of whats in the accel dfi ecu i put on the tvr in 1990!! ![]() It certainly was more advanced than that: http://www.allpar.com/cars/desoto/electrojector.html. Look a little down the page to see what the electronics look like. Jean good point jean ,one day i'll take the lid off and see.. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Nov, 2011 at 11:12:42am
Just to update the Peugeot IACV worked fine off the Jimstim. I had similar problems when trying out the valve when not fitted to the body in that the pintile comes out.
28th Nov, 2011 at 12:28:55pm
I have the start value set at 360. This ensures that the valve seats when the igntion is turned on. It will then travel to the value set in the table. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
