Page: |
Home > A-Series EFI / Injection > Runner length | |||||||
17th Feb, 2011 at 02:04:17pm
Even without a plenum, you have a reflection. You have a discontinuity which will induce a reflection. You can think of it as a plenum with infinite volume.
17th Feb, 2011 at 02:34:25pm
Jean is correct, doesn't make any difference whether you have a plenum or not. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Feb, 2011 at 02:41:35pm
ok. So what effect does the plenum have then? Do you put a value in for the distance from the bell mouth to the plenum 'wall'?
17th Feb, 2011 at 03:02:41pm
The plenum creates a sort of shock absorber for the waves created by the action of the valves. The effect of the positive wave moving from a port at high velocity to a plenum at low velocity is to promote a reflected negative pressure wave back to the valve.
17th Feb, 2011 at 03:18:24pm
On 17th Feb, 2011 Paul S said:
Your short runners will gain power, but at around 8000rpm upwards. Pity my rev limit is 7.5 k then! I can't see how I can make them long enough to have any effect. Maybe for the Mk2. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Feb, 2011 at 03:31:24pm
hence my new cam. On 28th Aug, 2011 Kean said:
17th Feb, 2011 at 03:43:32pm
On 17th Feb, 2011 Joe C said:
hence my new cam. Don't forget the new belt Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Feb, 2011 at 03:52:56pm
MioaoW!!!
17th Feb, 2011 at 06:54:10pm
what i'm going to do is see where the new cam makes peak, then make some manifold extentions that move the whole plenum forward, just means i'll have to leave the bonnet off.
18th Feb, 2011 at 01:26:29pm
Useful page from the book showing how the waves act:
10020 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
18th Feb, 2011 at 01:29:15pm
http://www.peter-burgess.com/flugelhorn.html If something is worth doing, it's worth doing half of. |
18th Feb, 2011 at 02:15:13pm
Thanks John.
18th Feb, 2011 at 03:09:18pm
Sorry Paul for dropping a bit of inane twitter into your thread but I thought this sort of shows your theory in practice.
Edited by John on 18th Feb, 2011. If something is worth doing, it's worth doing half of. |
16th Apr, 2017 at 03:53:11am
bit of time travel here but how did all this turn out some of the plots and pictures are missing
Edited by Turbo This.. on 16th Apr, 2017. |
16th Apr, 2017 at 01:29:07pm
Runner length will determine the shape of your torque curve and ultimatley your maximum power.
17th Apr, 2017 at 12:28:28am
ok far to long sounds like 350-400 from head face to plenum is where i need to be?
18th Apr, 2017 at 03:13:00pm
Based on the Engleman/Helmholtz formula which seems to be substantiated by simulations, a 500mm runner at 34mm bore will induce a peak VE/Torque at about 4000rpm.
18th Apr, 2017 at 03:21:15pm
big turbo and a big cam for a 1098 IMO, are yopu going to go large bore at some point? On 28th Aug, 2011 Kean said:
18th Apr, 2017 at 05:16:33pm
On 18th Apr, 2017 Joe C said:
big turbo and a big cam for a 1098 IMO, are yopu going to go large bore at some point? ??? The GT2052 is the new Garrett number for the GT1752 previously exclusively (?) used by OEMs. The Kent 274 is similar duration to the MG Metro but more lift and higher LSA. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Apr, 2017 at 09:00:38am
Ah!
19th Apr, 2017 at 11:14:12am
ok i was wondering why i couldn't see the gt 15 and gt 17 turbos on there page guess they just didn't sell them so culled them for a single and renamed it as the 2052
19th Apr, 2017 at 11:19:22am
big turbo big cam thought the 1098s don't like the rpms due to lack of journal over lap and 3 main bearings not to mention the piston speed
Page: |
