Home > General Chat > Carbon Fiber Roof, worth it?
how much do you want for the old roof??
On 16th Jul, 2009 MikeRace said:
Thats it your out of my gang now *Punch*
*Rofl!*
steve w
Member #: 1917
AKA chargedzetec
i realy dont see the point of the carbon roofs, get a fibreglass one and paint it black.
hardly any, if any at all, carbon products on the market provide a weight saving over fibreglass. After all, they're made in exactly the same way.
Dry carbon cloth doesnt weigh less than dry fibreglass cloth, and the resin is the same.
it all seems to be form over function, and alot of people wasting loads of cash.
my 10p worth!
I agree ^
it does seem like a huge amount of work for a few kgs, if I was you I'd simple remove some of the bars from the cage. That car was built to be on the weight limit of 660 with driver, so extra bars were added instead of addind ballast
Just to answer a few points from above.
The cage is T45 and is welded to the A & B pillars and along the roof line, so removing the roof will not affect structural integrity.
As for getting a car to run as fast as the DON or Nic's, well, we have a few years to catch up. Whichever way we do it, I'm not prepared to risk the safety of my kids in a race car without a roll cage. I know the incidence of roll overs is rare, but I just feel it would be irresponsible of me if we did not use a cage.
So the cage is sacrosanct and we loose some weight by substituting panels for starters.
Mine is FB, and was an absolute piece of pi$$ to fit. I did it in ab hour.
You just have to leave an inch gap all way round then hammer it down slightly to enable the roof to sit flush. Then i just Tigersealed it on.
Jobs a good un!
I wasn't aware of that. Thanks.
I'll have a look to see if we can take a few bars out then.
The remains of the steel roof are yours for free, Jim, but you will have to collect it. It would look good on your garage wall.
I'll collect it no problem, it will indeed be stuck to the wall in the workshop. I'll bring some alcohol of your choice with me
johnK
Member #: 690
Norfolk
Good stuff - 10kg's is 10 kg's in anyones book! Rob - I don't think Rover really cared about the integrity on the british opens - but they did bolt an incy frame in to support the roof.
- ref air pressure at speed - that was my point earlier about adding carbon/foam X bracing to the roof to give it some rigidity.
JK
If Carling made Mini engines
t3gav
Member #: 229
Gavin@minispares.com
kent
You could get a prepreg one from Carbon Weezel...
JK
I think we just need a couple of foam pads if it does try to collapse.
Thats a pretty substantial cage.
Are you really sure you want to be cutting the roof off this car?
Surely it will lose all of its value as it will no longer be suitable for most racing classes?
Is it not best to leave it on, or rob the shell of all its bits and sell someone a bare shell?
good thinking nic, all depends what long term you want todo with this car. It's almost identical to my car, and it's never going to be light enough to win Class D in drag racing. My guess is this car as carrying around 100kgs more than nics, or the Don.
It could be a top running on the circuit though, Whats your plan guys?
wabasto?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
its wetlay
And if what I have heard is correct, they actually use a lesser resin than some others. But they DO spend a lot of time on getting a nice finish to their products
http://www.minifinity.com/distribution/vie...php?f=7&t=81597
Edited by miniminor63 on 16th Jul, 2009.
MarkGTT
Member #: 1194
Shropshire.
my carbon roof came from curley - it was a pig to fit, and i ended up painting it black..
but to be fair to curley they only charged me as much as a fibreglass item.
i cut the roof out of mine as the original had a sun roof and the rest was dented beyond repair.
If your roof is sound i would just keep it as is.
sliding fabric roof
On 16th Jul, 2009 mini13 said:
wabasto?
My roof is fooked, so I'm putting steel back where it should be steel.
I've said it before and I'll probably say it again. Fibre glass is gay (IMHO).
You really are out of my gang!
Well, our percieved value to this car was the time it saved in preparing something similar from Sturgeos' Racing Flame. With 5 Minis in the family, we do not have the time to put into doing it from scratch. If you add the value of the Racing Flame and all the parts that we would have had to buy to get the car to this standard, the total would not be far short of what we paid.
We have no plans to "race" this car in any particular circuit class, possibly a few track days. But we do intend to get it on the road with an MOT and develop it for drag racing.
We accept that it will not be a practical road car, but we have less than 10 miles to get to the Pod. I've bought a trailer for longer runs.
We were told that the car weighed 540kg in Miglia guise. We will be adding weight by fitting the turbo, manifolds, intercooler etc, but there is scope to reduce weight in the roof. It also still has steel doors. We may be able to keep it around 540kg in road going mode.
Jim, I reckon that there is a 12.5 second run in you car. If you had sussed the problem with the flat-shift before Sunday, then you would have done it at the weekend. Your car is not too heavy to win Class D in my opinion.
Who knows where we can go with EFi on the five port, plus launch control, boost control, flat shifts etc ??????? I think we can use the electronics to negate the extra weight.
I'm building an all-steel K1200 headed 1293 for when we think we have reached the 5-port limit.
Now Sturgeo will come along and say something entirely different :$
sturgeo
Member #: 1778
Northants
As he said^
I don't intend on using the car in the miglias for example as i don't have the time or money.
There are certainly ways to make it lighter, ream beam axle is another thing on the list and i've taken out the heavy fire extinguisher system.
I too think a 12.5 pass is possible in jims, even though they are lighter we have got a lot more rigidity and should be able to get the power down better :)
sturgeo
Member #: 1778
Northants
I'm surprised none of you lot have recommended a cast iron roof *happy*
We seemed to have killed off the discussion anyway.
I thought you were going to cook dinner?
