Page: |
Home > Paul S trials and testing > Siamese Code Trial - With Boost | |||||||
8th Aug, 2009 at 06:03:27pm
On 8th Aug, 2009 Rob H said:
However it appears to be going a bit lean at the end is this the limit of the injectors? I think you are looking at the overun cut-out where it leans out to 22 odd. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Aug, 2009 at 06:04:29pm
That explains it, I wasn't sure what was vacuum & what was boost. Edited by Rob H on 8th Aug, 2009. Isambard Kingdom Brunel said:
8th Aug, 2009 at 07:09:34pm
Very good, I think we knew it would all come together in the end.... Thanks to Jean...
8th Aug, 2009 at 07:15:01pm
The LM-1 on the outer cylinders is very spikey. I'm tempted to get another LC-1 and compare the results.
6745 Posts Member #: 828 Post Whore uranus |
9th Aug, 2009 at 07:41:06am
excelent. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Aug, 2009 at 09:29:57am
On 8th Aug, 2009 Paul S said:
It's starting to get a bit dangerous now that we are spinning tyres and starting to feel a bit of torque steer. sounds like its coming along well, just need to get it to the "holly ****, cant take my eyes off the road and loads of torque steer" and i will be really tempted |
9th Aug, 2009 at 09:39:50am
It's starting to get a bit dangerous now that we are spinning tyres and starting to feel a bit of torque steer. sounds like its coming along well, just need to get it to the "holly ****, cant take my eyes off the road and loads of torque steer" and i will be really tempted It's only a 998 and probably around 115hp. Give me a couple of months (optimistic) and we will be going for 200hp plus on the Miglia. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Aug, 2009 at 10:45:54am
On 8th Aug, 2009 Rod S said:
As a matter of interest, how many cc do you inted to put on the Miglia ??? Had to think about this. I'm tempted to build the manifol to take 3 * 800cc/min injectors on each port. Two on top and another underneath. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Aug, 2009 at 11:02:29am
Presumably with 1 only for the first stage and the other 2 for the second stage ???
9th Aug, 2009 at 11:10:39am
Could you not use 2 injectors a small one for the first stage & bigger one for the second stage or have I missed the plot? Isambard Kingdom Brunel said:
9th Aug, 2009 at 11:19:51am
i think overall demand is requiring bigger inj than are common for 2 rob ,. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Aug, 2009 at 11:31:34am
It's a matter of individual size and total capacity for staged injection.
9th Aug, 2009 at 11:41:06am
On 9th Aug, 2009 Rod S said:
Presumably with 1 only for the first stage and the other 2 for the second stage ??? That would be the plan. I would use the Siemens 800cc/min high z injectors. For some reason I bought 4 * 600cc/min that are now surplus to requirements. I will try and lay out the design in CAD, but with the turbo at the side, I have room underneath the inlet manifold. On 9th Aug, 2009 Rod S said:
Have you done the mod on your second daughterboard for the staged injection yet - I've just got my second one and it looks like I'll need an even stronger pair of reading glasses than I already use for PCB work to do it safely, Mr Magoo type..... I haven't done the mod yet. Although I have recently aquired some new, stronger reading glasses myself, I let Sturgeo do all that kind of stuff. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Aug, 2009 at 12:01:23pm
reading glasses??
9th Aug, 2009 at 12:03:53pm
You have got me thinking (again).....
9th Aug, 2009 at 12:10:01pm
On 9th Aug, 2009 mini13 said:
reading glasses?? loosing my closup vision is not somthing i'm looking forward too as i get older, at the moment i'm the guuy peple come to if they wan somthing like this changed.... So we can send you all the MS2 daughterboards for modification? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Aug, 2009 at 12:17:56pm
On 9th Aug, 2009 Rob H said:
Could you not use 2 injectors a small one for the first stage & bigger one for the second stage or have I missed the plot? As Robert said, the problem is the availability of large injectors, although the situation is rapidly improving. If I'm limited to, say, 115hp at 6000rpm from 960cc/min per port, then for 250hp at 7000rpm, I need around 2500 cc/min per port. But I still need to be able to get it to idle with one injector per port. I'm currently getting a good idle from the 960cc per port, but I think that is at it's limit. So, if I'm limited to two injectors, I need a combination of 1000cc and 1500cc. But 1500cc injectors are like hens teeth. Hence the choice of three 800cc injectors. Just need to design a manifold to make them fit. EDIT: Just a couple of assumptions that have led me to this decision: 115hp from the 998 and have I actually hit the limit at 11-12mS pulse width. Edited by Paul S on 9th Aug, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Aug, 2009 at 02:00:03pm
can do Paul,
9th Aug, 2009 at 02:11:44pm
Joe,
9th Aug, 2009 at 02:16:33pm
no problem,
9th Aug, 2009 at 03:06:54pm
Paul,
9th Aug, 2009 at 03:28:42pm
It will physically fit (I've just measured) but then I have a new issue with low z... The TIP 122s on the P&H drive are only rated at 5A, injector peak current is 4A so I may need 6 P&H drives..... need to do some maths on the average current and power dissipation (or PM Jean !!!! ...) While you could change some components to drive 8A from one driver, I would not do it. The best would be to have 2 more drivers. With 2 injectors in parallel on the same driver, unless they are identical electrically and mechanically, one will be favored and open faster and the flyback will likely cause some interaction at closing time. Having said that, the standard MS drivers do work with low-Z injectors in parallel but given a choice I'd rather not do it. If you do want to do this, you'll need to change the sense resistor from 0.1 Ohm to 0.05 Ohm to have a 8A/2A peak/hold current and you will want to change the TIP122 to something more robust. You'd have to find a Darlington that can handle the 8A. Jean |
9th Aug, 2009 at 03:56:55pm
I've just done a quick calc to check the fuel flow and hp relate.
9th Aug, 2009 at 04:22:02pm
If you have an adjustable fuel pressure regulator, you could increase the pressure to make some more tests.
9th Aug, 2009 at 05:09:47pm
On 9th Aug, 2009 jbelanger said:
While you could change some components to drive 8A from one driver, I would not do it. The best would be to have 2 more drivers. With 2 injectors in parallel on the same driver, unless they are identical electrically and mechanically, one will be favored and open faster and the flyback will likely cause some interaction at closing time. Having said that, the standard MS drivers do work with low-Z injectors in parallel but given a choice I'd rather not do it. Jean, Luckily I'm at the point in my second build to be able to do this, six seperate drivers. However, with six drivers (two plus four) is the CPU capable of driving two LM1949 chips from a single ouput, ie, would pin 1 need a limiting resistor in the same way the CPU needs higher value limiting resistors if driving more than one Ignitor chip (ie, 330 ohms for one but 680 ohms for two) ??? Datasheet shows high impedance input, typically 3 microA, so I guess it's not a problem. Rod. Schrödinger's cat - so which one am I ??? |
Page: |
