Home > A-Series EFI / Injection > Megasquirt Injection question
On 31st Aug, 2009 Coupe said:
I'm running a pair of 650's in alternating mode. They're fine at cruise, although I am running the car a bit rich for the moment to be safe. I've got problems with idle at the moment, but I'm still working on that, and have an idle control valve to go on yet for cold starts, but there's no reason why it can't run and idle fine with injectors of that size.
Mark, you may benefit from the latest MS2/Extra code as it will allow you to time the injection event. It may help with your idle problem.
jbelanger
Member #: 831
Montreal, Canada
On 31st Aug, 2009 James_H said:
Im going to be running an emerald ECU
Why? Unless you already have it or can get it really cheap I don't see the point if you plan on going port injection later. The Emerald won't do it.
Jean
http://www.jbperf.com/
Hmmm really..
So what does the ECU need to be able to port inject the a-series?
I would most likely go 8 port before port injection but i would like to keep my options open...
I know it sounds stupid but i like the features of the Emerald, and trying to find out the features of megasquirt is confusing the hell out of me. I'm struggling to find a clear list of features for it.
Its all very technical, and while i'm not the type of person to shy away from getting involved and learning the hands on way, for my first EFI based project it all seems abit too deep for me at the moment!
Can Megasquirt be connected to a stack dash/datalogger (like Jimsters) ?
jbelanger
Member #: 831
Montreal, Canada
The ECU needs to have a sequential mode specifically designed for it. As opposed to what some will say, a regular sequential mode cannot be used. And, as far as I know, only Megasquirt has such a mode. Canems has a semi-sequential mode but it's not enough to really deal with the AFR mismatch.
And I don't think that the stack dash/datalogger will work with Megasquirt but you'd have to contact them. They may be able to adapt their code to communicate with it. I know that Innovate has done it with theirs to log data from Megasquirt.
Jean
Coupe
Member #: 2178
Leyland, Lancs
I take it I can run the code without any extra hardware?
As long as you have the MS2 daughterboard.
Coupe
Member #: 2178
Leyland, Lancs
Its a prebuilt MSII V3 from DIY Autotune.
sturgeo
Member #: 1778
Northants
Should be no problem, ours is the same but in kit form.
Users viewing this thread: none. (+ 4 Guests) <- Prev
