Home > Beginners Tech > Turbo box pictures
Dangerous
Member #: 417
paneermeel
Member #: 1404
The Netherlands
reading this thread i now realise how little room i have for the turbo and the actuator. my car is a LHD.
at the moment i have a brakeservo but i want to get rid off it to get a cleaner looking enginebay. but is there any room to put the clutch and brake resevoir above the pedals ?????
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
TurboDave16V
http://www.geocities.com/jharkola/1380turbo5.html
That is all you need. Nothing more. nothing less. That proves it can be done.
other option is mirage manifolds *smiley*
do a search on here if you havent heard of them.
no bulkhead mods then! *smiley*
paneermeel
Member #: 1404
The Netherlands
@Turbo dave: i saw the link before. but now i see that he started without the servo. so i will swop from servo to non servo brakes first. so when it's time to make the turbo box i see what i cab cut away.
@iain: i've seen mirage manifolds before. but that will mean extra cost's and apperantly the stock metro flows better. so thats a bonus to.
but thanx for the response
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
i knew that someone had a turbo in his lhd. so i emailed i's and this what i got back:
he tilted the block slightly forward and got enough room to get his hand between actuator and bulkhead.
so that is one more "problem"of my list
www.turbomini.nl
Nic got second in this year's Mini showdown with the Mirage manifolds. 13.6sec quarter was it? So, I don't think you should worry too much about that!
13.5 actually
i dread to think how quick the car would be without them.....
paneermeel
Member #: 1404
The Netherlands
i will be more then happy if everything will work properly....
*smiley*
at the moment it's a standerd 1000cc , so the power output of a turbo will be just fine for me:cool:
standerd or mirage...........
www.turbomini.nl
Arno
Member #: 233
Beugen, Netherlands
but not for long...*smiley*, try Rob van Balen, he's dutch and is driving a LHD mini. I do not know his username (admin??) but he maybe close to you.
Have fun
chinlesswonder
Member #: 1192
In the garage......again!!
ok, been reading this with interest, i'm just about ready to cut the bulkhead for the turbo box. Got the Avonbar box but the diagram is really crap that came with it. Anyone got any measurements for where to start the chop, ie, how far from the two holes for the master cylinders, how far down etc.
cheers
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Minimad69
Member #: 1311
Yeovil, Somerset
As for how far down, the box is shaped so that it will sit in one place only. Theres a lip on the left of the box that sits up flush under the main cross section of the bulkhead.
This pic shows how i fitted mine, the instructions were rubish so i just looked at as many pics on here of the work others had done and then judged it myself.
Hope thats of some help to you
Minimad69
Member #: 1311
Yeovil, Somerset
A close up shot, shows the positioning a bit better
Brocky
Member #: 224
Katy TEXAS
These are the dimemsions I used for the main plate cross-section (custom box), hope this helps, not gospel and only a guide.
as mentioned above,
and the width can be seen to be from the engine steady bracket to almost the tower bracket as the lower bulk head curves away to allow the n/s sub frame tower to be recessed.
The main plate was welded in first and then simply made up the 2 end plates to fit and welded in
The thickness of the box plate was as thick as the bulkhead plate which is the next size up from 16 gauge, I think *smiley*
As with all fabrication of this nature, patience, trial and error and in some cases a bloody big hammer are essential.
Edited by Brocky on 30th Jan, 2007.
chinlesswonder
Member #: 1192
thats a big help everyone, will let you know and post pictures of how i get on.
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Might aswel stick mine on here too:
Brocky
Member #: 224
Katy TEXAS
Nice to see some progress jim !*smiley*
Looks like its gonna be tidy
I hope mine will be big enough
Brocky
Member #: 224
Katy TEXAS
Yep looks fine, tidy car btw*smiley*
Thanx! :)
stuart_brierley
Member #: 5953
I bought a turbo box from Avonbar some time ago but only just got round to building the car. It came with the main box plus a separate blanking plate for the nearside end of the box. I couldn't work out how on earth that plate should be fitted. It just didn't seem big enough. So using the pictures here, I think I've got it roughly right. Here are some pictures. I am slightly worried there's too much bulkhead left. Perhaps someone could give me their oppinion. As you can see, I've had to add an extra triangle of metal to bridge the gap between the plate and the box and I'll have to fill in the old heater hose hole.
Mr Joshua
Member #: 1954
Luton Bedfordshire
I cut my cross member out all th way to the brace on the near side. That gave me the extra space for the induction pipe. It also looks like my box is slightly wider than yours.
Own the day
stuart_brierley
Member #: 5953
I see on the Avonbar website that they recommend moving the engine forward half an inch. I assume this will help clearance at this point too.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Stop the turbo smacking into your new lovely box.
Own the day
