Page: |
Home > Show Us Yours! > Minus 7 port turbo | |||||||
2093 Posts Member #: 9894 Post Whore Dorking |
9th Dec, 2015 at 09:18:11pm
Changed my mind again on an intercooler. Found this of a mazda 323gtx. It fits perfectly, its not massive but with a nice duct it should be quite capable.
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
10th Dec, 2015 at 08:43:30am
That,s not dissimilar to the one from a Punto Gt, which I have on the A35 |
20th Dec, 2015 at 11:36:46pm
On 10th Dec, 2015 tadge44 said:
That,s not dissimilar to the one from a Punto Gt, which I have on the A35 Does look very similar. I hope it's up to the job. |
20th Dec, 2015 at 11:38:33pm
I've started on a duct for the intercooler. Hopefully it will get enough air through it. I will probably cover it in something to keep the heat away.
537 Posts Member #: 8926 Post Whore Sheffield |
22nd Dec, 2015 at 03:36:57pm
Where did you get the fuel lines from mate?
On 27th Nov, 2015 jonny f said:
Engine is almost ready to go :). Water pump and controller are sorted and nearly everything is wired up. It's taken me a while to sort the actuator out but i'm fairly happy with this. Just needs tidying up and painting. Knocked up a new little dash with afr/boost gauge, oil pressure, voltmeter (in the post). Can see the water pump controller on the right, this also controls the fan. Fuel lines. I am waiting on an intercooler. I did want to sort something in the inner wing with a duct but i've given up searching for an intercooler of a standard car that would fit. Gone for a 2wd cossie behind the bonnet with a few holes in the bonnet. Although i'm going to try something a little different with the holes. |
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
22nd Dec, 2015 at 03:58:28pm
Actuator bracket looks good, might have to look at something similar for mine when I get the time. Are you fuel lines made of plastic or something? |
22nd Dec, 2015 at 05:03:42pm
The fuel lines are alloy from demon tweeks. Krontec stuff. I used a small hand held bender to do the bends.
Edited by jonny f on 22nd Dec, 2015. |
22nd Dec, 2015 at 05:17:11pm
It's close .
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
22nd Dec, 2015 at 05:23:32pm
Exciting times! Apart from the obvious hose its almost a stealth turbo install at quick glance.. On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
22nd Dec, 2015 at 05:26:54pm
Cold air feed |
2742 Posts Member #: 637 Post Whore Hertfordshire |
22nd Dec, 2015 at 06:51:08pm
Looks spot on mate!
My build thread..
489 Posts Member #: 9159 Senior Member Devon |
22nd Dec, 2015 at 07:32:53pm
Nice work on the duct, did you make a mould first? I've got lots of fiberglassing ahead of me. |
22nd Dec, 2015 at 07:34:17pm
On 22nd Dec, 2015 JT said:
Looks spot on mate! Hopefully see this at ace cafe in the new year sometime! Have you got a leccy pump plumbed in to the dry deck hose? Thanks, yea hopefully make a trip up there when I feel like sitting in traffic lol. Yea just on opposite side. Rad hoses are still on other side. |
22nd Dec, 2015 at 08:47:57pm
have you done away with the mechanical pump then? My build thread..
22nd Dec, 2015 at 09:14:16pm
have you done away with the mechanical pump then? Yep, no mechanical pump. The pump runs off a controller to. It controls engine temp, don't use a stat. Also brings in the fans if the pump won't shift enough water to cool the engine. Can adjust engine temp etc inside the car, keep moving water after turning car off etc. |
22nd Dec, 2015 at 10:04:19pm
Sounds good jonny.
My build thread..
23rd Dec, 2015 at 05:34:39pm
New plenum. Thanks Matt. Fits all good.
Edited by jonny f on 23rd Dec, 2015. |
336 Posts Member #: 9941 Senior Member Derby |
23rd Dec, 2015 at 08:15:35pm
I'd swap to a standard Inlet manifold |
23rd Dec, 2015 at 09:58:46pm
Gets to close to the bulkhead with standard one. |
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
24th Dec, 2015 at 01:39:24pm
Take the black spacer off I have started posting on Instagram also my name on there is turbomk1golf
55 Posts Member #: 8837 Advanced Member Warwickshire. |
25th Dec, 2015 at 09:33:07am
Looking really awesome dude. Hopefully you can get it all to fit under the standard bonnet. 1976 Mini 1000 FWD R1 - 13.2@104
28th Dec, 2015 at 08:51:38am
It'll fit with the turbo mani :). I just need to modify the carb a little. |
28th Dec, 2015 at 10:17:39am
Isn't a alloy na one better flowing than the turbo one anyway? My build thread..
28th Dec, 2015 at 10:34:09am
someone before me has milled my current manifold to tilt/lift the carb
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
28th Dec, 2015 at 12:11:56pm
Might sound daft but how did you connect the fuel hose to the hardline? With a tube to -6 then a -6 to 8mm barb? On 26th Jan, 2012 Tom Fenton said:
Page: |
