Home > Show Us Yours! > 1293 turbo saloon, update 26/06/14 running again, mot time
supermotolee
Member #: 2153
kings langley
Cool, are you running an angry looking paddle and a heavy spring?
eden7842
Member #: 8852
leicestershire
Grey and a 5 plate paddle. It's super fierce
eden7842
Member #: 8852
leicestershire
Getting very close now, hopefully fire it up and knock the cam in back end of the week.
Edited by eden7842 on 19th May, 2014.
t@z
Member #: 452
Chester, UK
looking good man, that water hose looks like and elephants trunk :)
www.twitter.com/lilpinkiy
eden7842
Member #: 8852
leicestershire
Cheers tax, yeah it's been cut and fitted now, was just placed before.
Well its fired up tonight, still gota Finnish some plumbing but I had to check it sounded ok which it does! Sounds incredible!!!
Made my screamer pipe well chuffed with it.
Good stuff!
looks neat
t@z
Member #: 452
Chester, UK
you may want to wrap that screamer pipe if that pipe touches. also when your giving it some beans and you stop dont panic if your bonnet starts to smoke. after i had wrapped mine i went for a bit of a jolly being a bit asbo, got to sainsburys and looked like my car was on fire but it was just the wrapping smoking.
eden7842
Member #: 8852
leicestershire
Cheers guys,
It's actually miles away from anything but il be sure to keep my eye on it. Want it to go purple!
Nick warwick
Member #: 8926
Sheffield
Nice work mate!
supermotolee
Member #: 2153
kings langley
They get warm that's for sure mines well whrapped now it tried to melt everything close to it!
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Hahaha, that screamer pipe is brilliant!
On 7th Nov, 2008 Nic said:
naeJ
m
eden7842
Member #: 8852
leicestershire
Il get some more pictures tomorrow hoping to get some more work done. I want a support on the vent pipe and one on the screamer itself.
There should be quite good airflow through the engine bay as I'm going to drill my a-panels too
lee.pb
Member #: 9199
Lancashire
You cant beat a good screamer *smiley*
eden7842
Member #: 8852
leicestershire
Small update, knocked the cam in all is well.
Tho the screamer is loud on Idle. I forsee issues with the man!
lee.pb
Member #: 9199
Lancashire
Shouldn't the external waste gate be closed at idle so no noise *Clapping*
Or am i missing something *oh well*
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
on my tial gate both side of the diafram that can be connected but only one is needed along with the desired spring pack to set boost of cause
eden7842
Member #: 8852
leicestershire
The way I have it plumbed up with my boost controller opens it off boost.
Idea is that is releases the pressure removing load from the turbo when it's not needed.
Tho I've got to test drive yet so still gota check it spools up!
1293 sprite
Member #: 5449
Melton Mowbray
That reminds me, I still need to collect your old wastegate! Although I may wait until you've got the mini running *wink*
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
eden7842
Member #: 8852
leicestershire
Haha Ok mate, it's basically there now few niggles to sort out tonight hopefully get a test drive in tomorrow 👍
eden7842
Member #: 8852
leicestershire
Here's a link to a quick video.
Need to sort the suspension and tracking so I can up the boost and go straight!
Edited by eden7842 on 24th May, 2014.
1293 sprite
Member #: 5449
Melton Mowbray
Sounds lovely :).
17.3 1/4 @ 78 mph
Sounds great Eden!
lee.pb
Member #: 9199
Lancashire
very nice, sounds great
eden7842
Member #: 8852
leicestershire
Cheers guys.
As it stands all seems well. Had some oil spill out of my breathers so got to make a catch tank setup.
Had to up my rev limiter to 8200, with my shift light at 7800. Runs like a champ.
One of my core plugs has sealed itself up and the other is slowing down now. As for the cooling system I think I'm going to need to run a stat as when I was blasting around yesterday it couldn't hit 75c
And last thing, something to bear in mind my Tim temp gauge reads 10c higher than my electronic pump controller so I think it shows how poor the Tim gauge is.
Users viewing this thread: none. (+ 3 Guests) <- Prev   Next ->
