Page: |
Home > A-Series EFI / Injection > reverse engineering the mpi | |||||||
4559 Posts Member #: 786 Post Whore Bermingum |
30th May, 2006 at 10:41:38pm
Edited by Bat on 30th May, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
30th May, 2006 at 10:51:51pm
On 30/05/2006 22:41:38 Bat said:
Hi, As far as I know, only one lump, like a cam lobe.... Cheers, Gavin :) That makes sense but I was thrown off by this which seems to say differently: On 30/05/2006 21:56:18 Mini Sprocket said:
The camshaft position sensor has two functions. The first is to enable the ECM to run a sequential fuelling mode. The second is to measure the actual cam period, this measurement is achieved using teeth on the camshaft to indicate when the valve opens and closes." |
30th May, 2006 at 11:09:27pm
Page: |
