Home > 998cc > 12g295 head!what to do
unlucky V,
PaulH
Member #: 2340
Dublin Ireland
we have one just like that siting in the workshop stores V how blody upseting :(
On 17th Feb, 2009 Rob H said:
Advantage
Member #: 1450
Near Paris - France
This is scaring me !
I bought a 295 a while ago and now realise I didn't check it properly so far ...
Is bead blasting the best option ?
I red somewhere heads can be welded ?
Rusty by nature
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I'm sure heads can be welded in some cases but Veggard's 12G295 was cracked across a valve seat. I can't imagine that can sucessfully be repaired with weld. Maybe simple repairs can be done to waterways etc. but I can't imagine much else can be welded.
All these heads are over 30 years old now (or something like that). I wouldn't trust any head I found a crack on as I could not be guaranteed that it has no more cracks or how long it would last
On 30th Apr, 2010 Rod S said:
Gary's description is best
My machinist says that he can fit two valve seats and thi might possibly work. After all, it depends on how deep the crack is. However, as heads are relatively cheap, it's better to find another one..
I now ALWAYS bead blast chambers BEFORE starting modifying heads. It's fucking annoying when you've spent 20hours on a head and when you grind the seats you find cracks. Never again!
GaryOS
Member #: 2810
Dublin, Ireland
I learned that the hard way too Vegard. I even spent €250 on a die grinder to mod my own head only to find it was cracked after the work. I ended up just getting a head from Benross as I got very pissed off aout it
PaulH
Member #: 2340
Dublin Ireland
He really did even a cuppa and a kimberley did not cheer him up :(
if they are cracked between the seats there SCRAP!
Most likely yes, but you wont know until you grind away meat for valve seat inserts and having it Magnafluxed.
i havent got the yellow bible to hand, how thick should the deck be between the face and the bottom of the oil gallery on a std head?
Viz states 0.060"
Dont do it.
reason i ask paul is this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=016
but it sounds as though this is about standard too
I've done a couple with slightly less than .060 Still works.
That head is ruined. The BAC has fitted 1275 valves. This might be rectified, but it's silly money for junk. Much better to find an original one.
Edited by Vegard on 10th Nov, 2008.
Carl S
Member #: 1761
Stalker
I have a 12g295 head if your interested joe. It was reconditioned a few years back, not sure whether it was skimmed at all though, it doesnt appear to be.
cheers soap, the problem was my cr was too low, and its ethically wrong to skim a decent 295 (i have no evidence to base this on, but its generally regarded as fact)
but paul being a gent has sorted me out with some flat top pistons to use instead of dished ones which wil raise the cr without having to skim the head
most heads start out 2.75" thick at the factory, so get the measureing wand out to see if yours has been skimmed or not, may be of use to someone else on here?
Carl S
Member #: 1761
Stalker
Oh right ok, I just saw your link to the head for sale on ebay and thought you may be looking for another head! whoops!
I will check mine thoroughly for cracks and check the thickness as well when i get back home at christmas from uni. I will put it up for sale then when I get round to it :)
