Page: |
Home > Show Us Yours! > T2 water connectons and Oil Drain | |||||||
![]() 102 Posts Member #: 180 Advanced Member Northants |
15th Oct, 2006 at 11:23:11pm
Could some one tell me the type of banjo used? eg bsp,metric and the size on the banjo itself and the hose insert as i may be able to get them as we keep alot in stock and i work for a hydraulic company the same as pirtec just alot cheaper. Also forgot the banjo bolt aswell! |
93 Posts Member #: 1212 Advanced Member braintree, essex |
18th Oct, 2006 at 10:18:53pm
i think they are 14mm banjos. can u get me some? |
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
1st Mar, 2010 at 12:16:17am
Edited by munnracing on 1st Mar, 2010. |
![]() 384 Posts Member #: 4215 Senior Member |
23rd Jun, 2011 at 02:21:49am
hi everyone,
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
23rd Jun, 2011 at 06:34:15am
Thats exactly what I did, Jim, with the GT17, which has a similar problem. |
23rd Jun, 2011 at 08:23:41am
standard heater hose on the van On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
23rd Jun, 2011 at 09:23:46pm
so normal rubber water hoses are fine then? i do have mine wrapped with a bit of exhaust wrap. and will be wrapping the manfiold next...
23rd Jun, 2011 at 09:38:50pm
Not sure if ordinary heater hose will last too long so I used 8mm copper to get the pipes clear of the turbo and then silicone hose. |
24th Jun, 2011 at 08:01:53am
We've used heater hose and routed it away from the hot side of the turbo and exhaust.
Page: |
