Page: |
Home > Help Needed / General Tech Chat > Supercharger Basic Setup - Questions | |||||||
30th Dec, 2022 at 05:42:43pm
On 30th Dec, 2022 stevieturbo said:
On 30th Dec, 2022 JonnyAlpha said:
Correct the MPI (or any VR senors) emit a sine wave. The ECU can be (and mine is) fitted with a VR Conditioner that converts the Sine Wave into the required Square wave: https://wiki.speeduino.com/en/boards/VR_conditioner Or just use a correct sensor from the outset. There is nothing incorrect about that setup. Using the appropriate input conditioning circuit for a sensor doesn't make either the sensor or the circuit incorrect. A Speeduino ECU is a DIY project and you can set it up in many different ways for many different setup. And a VR sensor is perfectly fine for this application (could even be superior in some instances). Jean |
3588 Posts Member #: 655 Post Whore Northern Ireland |
30th Dec, 2022 at 08:05:29pm
Correct the MPI (or any VR senors) emit a sine wave. The ECU can be (and mine is) fitted with a VR Conditioner that converts the Sine Wave into the required Square wave: https://wiki.speeduino.com/en/boards/VR_conditioner Or just use a correct sensor from the outset. There is nothing incorrect about that setup. Using the appropriate input conditioning circuit for a sensor doesn't make either the sensor or the circuit incorrect. A Speeduino ECU is a DIY project and you can set it up in many different ways for many different setup. And a VR sensor is perfectly fine for this application (could even be superior in some instances). Jean And so is using a simple hall sensor without external add ons, which adds points of failure or error for what is a critical sensor/input. A VR sensor IS fine, when it is what the ecu is happy receiving directly. 9.85 @ 145mph
30th Dec, 2022 at 09:35:46pm
A VR sensor IS fine, when it is what the ecu is happy receiving directly. Which is what his setup is. A Speeduino with that VR board is not some kludge but one of the normal supported hardware configurations. It's no more a new failure point than any of the other hand-soldered components on the board. Jean |
28 Posts Member #: 12124 Member South West |
1st Jan, 2023 at 05:10:28pm
Correct the MPI (or any VR senors) emit a sine wave. The ECU can be (and mine is) fitted with a VR Conditioner that converts the Sine Wave into the required Square wave: https://wiki.speeduino.com/en/boards/VR_conditioner Or just use a correct sensor from the outset. Can you get a Hall Effect sensor like the MPI one with a protruding probe? As this is the type I need to mount behind the Crank Pulley to pick up the grub screws that are mounted in the back of it. Speed is just a question of money, so, how fast do ya wanna go? |
256 Posts Member #: 11017 Senior Member Shropshire |
1st Jan, 2023 at 06:21:36pm
Why do you think you need the 'probe'? |
1st Jan, 2023 at 08:23:54pm
you can get many shapes and sizes of hall sensor.
7th Jan, 2023 at 11:33:48am
On 1st Jan, 2023 Steve220 said:
Why do you think you need the 'probe'? Because this pulley is designed to have 35 grub screws inserted into the rear side, that act in lieu of a trigger wheel. The sensor probe extends beyond the out circumference of the pulley to sit over and pick up the grub screw heads. https://i.imgur.com/0gmrKFM.jpg Speed is just a question of money, so, how fast do ya wanna go? |
7th Jan, 2023 at 05:16:10pm
VR sensor for the crank is my choice, no electronics inside it, jut a coil and magnet, and the electronics (conditioner circuit) is nice and cosy in the ECU case.
Edited by Rod S on 7th Jan, 2023. Schrödinger's cat - so which one am I ??? |
Page: |
