Home > 998cc > New 998t Build
wilsonc001
Member #: 11333
So we didn't get many miles done this year either. It appears to have been building excess crank case pressure which was causing oil to get into the clutch. A combination of not enough breathing, to wide ring gaps, and possibly not quite aggressive enough during the run-in. Hey-ho.
Oh, and it popped a head gasket on a test run *indifferent*
Anyway - what's next? Well...this lot...
Another 998 (can't change that now!) but this one has had a bit more work done...
+60 block, re-ground crank with matched primary gear, ACDodd RS FI cam, and a CalverST St3 head.
CR should be around 9:1 with the chamber CC I asked for.
So the job this winter is to do the dry build and get the block back to Mr Dodd for final decking and oil squirter install, then get another gearbox built up.
Steve220
Member #: 11017
Shropshire
Nice! Didn't think Dodd did oil squirter work? I was told on multiple occasions he didn't.
wilsonc001
Member #: 11333
After seeing that there's some demand for it, he's going to use this block to tool up for fitting the BMW squirters.
wilsonc001
Member #: 11333
And they're in!
shane
Member #: 1246
Lowestoft, Suffolk.
When you dry build, check the clearance between the underside of the piston skirt and the the nozzle at BDC on all four pistons.
If the facing cuts to get a flat surface are deep you may have pistons touching jets.
Shane
Steve220
Member #: 11017
Shropshire
Usually people notch the pistons to clear.
wilsonc001
Member #: 11333
Nah, I was just going to run it and let them self clearance, what the worst that could happen?
No, of course clearance will be checked during the build.
shane
Member #: 1246
Lowestoft, Suffolk.
If care is taken this is not necessary.
Shane
wilsonc001
Member #: 11333
Finally checked and...loads of room!
