Home > Show Us Yours! > Rwd Mid Mounted 20V Turbo VW powered Mini
hazpalmer
Member #: 9038
Carlisle, Cumbria
Looks like some good work going into this!
Mini_matt_106
Member #: 11947
This is amazing! Looks like you are cracking on quite quickly too!
ArnieWallace
Member #: 12056
Still tinkering away at the Mini when time allows, at it one year now.
Seat base/subframe with handbrake mounting and harness points fabbed up and fitted.
Harness bars
Cooling system fitted and fans.
Intercooler to manifold pipe.
Exhaust in 2.5" stainless.
Run up to temp and all good with 2 stage fan control.
Cheers.
e5tus
Member #: 10128
Dorset
Some good work here Arnie. I like the drop in subframe for seats/handbrake, keeps it away from the fragile floor, but please tell me you are fixing it down too?!
ArnieWallace
Member #: 12056
Yes its all being welded in, the rear to the cage crossbar and the front to the original Mini seat crossmember. Thanks for asking. *smiley*
ArnieWallace
Member #: 12056
Ducting made to flow air through the intercooler.
Bulkhead and closing in panels.
Started to make up dash panel in fibreglass.
And its out for a test run, starts, stops and does all its meant to so far.
YUM !
e5tus
Member #: 10128
Dorset
Congrats on the test run, always helps boost the enthusiasm!
shane
Member #: 1246
Lowestoft, Suffolk.
I love how this car doesn't suffer stupidly wide track as some of the rear conversions do.
Keep up the good work.
Shane
