Home > Track, Drag & Race > Fastest street driven A series?
On 21st Jul, 2020 steve1275 said:
Went to the Pod yesterday with the slicks swopped for 888s, so sort of street tyre, and ran a best of 11.9/114 and 1.7 60ft. Well pleased. *Cloud 9*
Excellent mate, well done
Once Simon stops playing about on low boost he should see some 11s runs too *happy**happy*
steve1275
Member #: 951
Bromsgrove
Cheers Brett, yes I gather it will be next year before the Simon beast is revealed *evil* *hehe!*
'Where does the engine go?'
steve1275
Member #: 951
Bromsgrove
Latest dyno results gave 215 bhp, then 277 bhp with NOS, and 288 lbf. ft. torque. Power held up well beyond 6500 although peak was 6100. I'm using an Avonbar PH1 cam supplied by Ian Hargreaves and although it loses some low speed grunt it does exactly what want on the strip, running between 4 and 7000 revs
well done steve ...what boost ?
Well in mate 👌👌👌
Always pushing forward 🤘😎🤘
steve1275
Member #: 951
Bromsgrove
Boost was around 20/21 psi. When I tried a bit more the dump valve started leaking, now have a stronger spring on the way. Hopefully with that installed I can tweak the boost to about 23 and hit the magic 300 bhp. Don't think the transmission will take any more.
Have you considered not running a dump valve steve ?
The theory being , if you change gear fast enough the back flow is not enough to kill the compressor , and the wheel speed on the turbo will not drop ,and so you get a big jump in torque on the next gear ...
steve1275
Member #: 951
Bromsgrove
Interesting theory Robert, could it damage the turbo if I shift too slowly? My shifting is not the best, combination of old age and excess of mechanical sympathy.. *crying*
Edited by steve1275 on 10th Jun, 2021.
i am not sure .*smiley*
tadge44
Member #: 2500
Buckinghamshire
Practice your gearchanging Steve !!
Robert, I was past your house on Sunday on my way to Pinnocks farm to view an MG Midget but was not sure if you were here or across the pond
tadge44
Member #: 2500
Buckinghamshire
yup i am here !
steve1275
Member #: 951
Bromsgrove
So back to the Pod yesterday, managed a new PB 11.85 @ 114.7, off a 1.71 60 ft. Car felt good, but there is more to come, as i need to launch the car better. I moved the intake temp sensor to the engine side of the NOS injector, previously I saw 60C , now 20C, significant cooling effect.
excellent well done steve .
e5tus
Member #: 10128
Dorset
I bet it was a little toasty in the nomex! Great result, congratulations.
Edited by e5tus on 20th Jul, 2021.
Superb!
Phil.
steve1275
Member #: 951
Bromsgrove
Thanks guys, and yes it was a little toasty at times. I picked up a high speed misfire which I suspect was heat related.
steve1275
Member #: 951
Bromsgrove
So a stronger dump valve spring resulted in more power, and I practiced gear changing as instructed. Went back to the Pod yesterday and ran 11.78 at 115.3, so well pleased with that. *Cloud 9*
steve1275
Member #: 951
Bromsgrove
Hmm, took the head off and found this. Bit of detonation in no 1 methinks. Although I've been running higher boost this year I'm also using MS109 race fuel, and if the det was happening all the time I feel the damage would be worse. However I did run out of fuel half way up the strip once, and also did a couple of runs on pump fuel. The ali scraped off the bore quite easily, and although I can see scuffing on the top land, the ring appears to be OK. Thoughts?
melted piston, too lean
steve1275
Member #: 951
Bromsgrove
Do you think that was caused by the car leaning out when I ran out of fuel? Normal AEM reading is around 12 on the strip.
steve1275
Member #: 951
Bromsgrove
So, back to the Pod last Monday, lovely day for it, ran 11.72 at 115.66 off a 1.68 60ft. Dump valve ok now I've realised that the MS109 fuel gets into it when i'm using NOS and this caused big wear and sticking of the piston if not cleaned out. I flush the rest of the system anyway.
Users viewing this thread: none. (+ 2 Guests) <- Prev
