Page: |
Home > Technical Chat > Let's discuss breather systems... | |||||||
3588 Posts Member #: 655 Post Whore Northern Ireland |
25th Sep, 2017 at 09:44:49pm
On 25th Sep, 2017 TurboDave16V said:
Folks normally just drain and dump the catch tank fluids. If you did insist on returning them to the engine (why not if it is indeed clean oil - verify first) you'd need to put a ball valve or similar on the drain, opening it when you put the mini in the garage at the end of the day, and closing it before you next start it up. Otherwise, it's a almost a closed system, and no oil will drain to the sump with the engine running... I guess you could put a solenoid valve on it, but you'd need a huge flow (large port) to effectively dump it. On 25th Sep, 2017 Rammie2000 said: So if i read all this correct. A good catch tank with steel wool in it with the top above the valve cover and a return to the sumpplug ( with a banjo fitting sandwich between a lengthened plug) and a breather on dizzy hole and fuelpump hole ( since in my example the breather hole from the clutch housing is taken for the oil retutn of the turbo) would be an ideal set up. ?? Gravity will ensure oil can return even while the engine is running, and when the oil return is below the level of oil, that is effectively a vale of sorts to prevent crankcase pressure blowing up that line Even if this return was above the level of oil, oil will still have time to return without too much difficulty. You arent on the throttle all the time, and oil is still fairly heavy so it can still return ok. Worst case that it doesnt when running...it will again when you shut it down. But for keeping smells away, routing the final breather into the inlet tract somewhere should take care of that. 9.85 @ 145mph
25th Sep, 2017 at 11:35:33pm
Yeah, good point about the drain being in the oil hence acting like a valve, but it'll still have pressure on it which will ( I believe) reduce the velocity of the air in the breather line and reduce the ability for the air/oil mist to separate. On 17th Nov, 2014 Tom Fenton said:
26th Sep, 2017 at 03:47:31pm
The oil blocks any pressure from that side. There will..should never be enough crankcase pressure to blow oil up a pipe.
Page: |
