Page: |
Home > Show Us Yours! > Stateside 998c Build Thread | |||||||
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
6th Apr, 2016 at 06:47:41pm
I am also loving the tools! I have started posting on Instagram also my name on there is turbomk1golf
168 Posts Member #: 10666 Advanced Member California, USA |
14th Apr, 2016 at 05:55:33am
All this talk of my tools is making me a little uncomfortable :)
6729 Posts Member #: 618 Post Whore Glasgow |
14th Apr, 2016 at 07:48:37am
the new cones will settle in time but I've known a few people that have had to machine a little off the hilo to get it a bit lower. Mine is currently running without the locknuts to get it sitting right |
14th Apr, 2016 at 08:44:48am
I had to cut the bolt head part off the hi-lo (keeping the locknuts), then adjust height from the top side. It was never going to settle as much as I needed it to. |
14th Apr, 2016 at 09:40:41pm
Dang! That's pretty disappointing about the hi-los maybe needing some mods to get them low enough. Seems like removing the locknut will get me pretty far. Just getting the engine in and sitting on the wheels seems like it helped it settle a bit. I'll drive it a bit and then lock into taking the locknuts out.
18th Apr, 2016 at 04:50:26am
Got myself to a point where I could try and start the car today. Spent some time sorting out some mistakes I made hooking things up and then tried to turn it over.
2094 Posts Member #: 9894 Post Whore Dorking |
18th Apr, 2016 at 07:55:18am
There is an intial carb setting.
18th Apr, 2016 at 05:04:58pm
Yep found it. Set the jet to be flush and then go two turns clockwise on the screw. I imagine I did that but it was so long ago I'll check it out.
19th Apr, 2016 at 05:39:19am
Tried again today and found some issues:
21st Apr, 2016 at 03:49:45am
Thanks to everyone that has helped.
Edited by seahuston on 21st Apr, 2016. |
21st Apr, 2016 at 09:00:31am
mine took a bit of time to initially get started and run properly before I could bed the cam in; given its been apart twice now, I've not experienced and cam wear under inspection. |
22nd Apr, 2016 at 05:52:18am
Nailed it!
Page: |
