Page: |
Home > Show Us Yours! > 998cc Gt1548 FI | |||||||
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
22nd Jun, 2016 at 07:44:18am
That is the cleanest and neatest instal I have seen. |
684 Posts Member #: 9590 Post Whore Derby |
23rd Jun, 2016 at 07:35:03am
Thanks for comments guys, just finished wiring loom got to put it on car should have it firing up over next couple of days! Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
293 Posts Member #: 10010 Senior Member Northants |
30th Jun, 2016 at 12:54:16pm
Did you not consider running a plenum of sorts? They aren't needed for injection unlike of you were running a HIF44, but the little experience I have of turbo cars has shown that you can normally get a bit more power with one. |
3rd Jul, 2016 at 08:46:19pm
In short yes did look at making a plenum but just chose the easiest route to get going, maybe something to look at in future.
Matt W
132 Posts Member #: 9142 Advanced Member Nottingham |
3rd Jul, 2016 at 09:43:35pm
Ive got a wasp one on mine mate and it's fine so far no problems, we used them on the e-types and Listers at work too! |
4th Jul, 2016 at 07:37:57pm
Ill look into those Harry, I'm sending this starter back again.
Matt W
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
4th Jul, 2016 at 09:24:33pm
Matt, you need to make sure Brise are using the correct gear on the starter, I had this problem on an engine I built, chewed two ringears and two gears on the motor and as a result of poor engagement fucked the starter up, you need the largest dia gear they make to get best engagement and there are three different tooth counts available
5th Jul, 2016 at 06:33:42am
Carl thanks for the advise I will be sure to look into it before asking to be sent another one. I didn't think the width of the starter gear looked as wide as the gear on the standard starter either! Matt W
336 Posts Member #: 9941 Senior Member Derby |
9th Jul, 2016 at 05:41:39pm
Matt Incase you decide to get a refund I've got a wasp starter on mine had it about 4 or 5 years and it's perfect never had a problem with it. |
11th Mar, 2017 at 05:25:53pm
So after not doing much with this last year I've started to get it back in motion.
Matt W
3074 Posts Member #: 1348 Post Whore wakefield West Yorks |
11th Mar, 2017 at 05:28:38pm
Looks great Matt , that's a shame hope all goes better this time . Shouldn't have a problem down at emerald |
11th Mar, 2017 at 08:13:22pm
Cheers rick, hopefully get out on some track days with you this year! Your car is lookjng brill by the way Matt W
12th Mar, 2017 at 11:52:00am
Thanks mate, yes definitely need to get back out ! |
Page: |
