Home > A-Series EFI / Injection > Coil configuration with Micrasquirt
On 17th Dec, 2015 jbelanger said:
On 17th Dec, 2015 gr4h4m said:
Got to agree with Tom. The world has moved on, I have spent my life in the computer industry, and I couldn't be bothered with all the research, it's all about out of the box features.
Then how do you choose the ECU to use for the feature you need? You do need to do some research. That's the same for Megasquirt. You have out of the box features that are different depending on the model you choose from the Microsquirt all the way to the MS3Pro.
And then you have added options if you want to learn more and do more with the lower end units. That's not a problem but an added feature. And there's the additional benefit of not depending on someone else for anything related to the ECU and saving the associated expenses.
Look at Paul S latest build. His effort is not spent on the ECU but on the wiring and the engine and its components. And he uses a standard MS3/MS3x with no modification that you can buy fully assembled (or assemble yourself).
I read the link you posted (shown below) it shows soldering resistors, and then finding coils that work with it?
http://www.msextra.com/doc/pdf/html/Micros...are-3.4-58.html
My point is IT is moving so fast software doesn't even have "ok" buttons anymore. To be honest most of the Ecu software I have ever used (not many) or seen screen shots for, look like they were written to run on the Ark. They lack massively in the UX department. I can't wait to see how everyone is going to keep up with windows 10.
Even with a basic understanding I think most people will find it hard to tune a car properly, even with the auto tune options. A good tuner will short cut that massively, so by using the software and hardware that they are familiar with will also assist with the speed and quality of the tune. i think the best advice I would give is to pick a tuner you trust that is willing to tune your car and go with their recommendation.
I have no hate for megajolt.
jbelanger
Member #: 831
Montreal, Canada
I definitely agree that tuning in an essential part and that it is not as easy as some think or some would lead you to believe. So having someone who will be able to do it efficiently and with good result is valuable.
Unfortunately if you use some tuner recommendation, what often happens is that you get something that is good for the tuner because they also sell the ECUs and/or it's the only one they know how to use. A good tuner should be able to handle more than one brand and help you get what's best for you.
But even a non-optimal ECU well tuned is better than the ideal ECU that is not correctly tuned.
As for keeping up with Windows 10, the software used with Megasquirt runs on java so it is multi-platform. And according to people who have experience with many ECUs, it is one of the good ones. (I know that java has its own issues but the software is actively maintained and developed)
And the link I gave is just the first page. The following pages give a host of different options for coils and ignition drivers for many of the most common applications. If yours is not there, that would indeed require more research.
And the resistors are only for the "extra" features which are not the out of the box features. And they are simple enough that they can be done as part of the wiring.
http://www.jbperf.com/
IMO part of the biggest problem with a lot of modern ecu's is the tuning software. Some makers seem to think flashy colourful screens, with loads of menus, submenus some at the top of the screen, side of the screen, hidden accessible only via mouse etc etc....are a total fucking nightmare to actually use when sitting in a car with only a keyboard to hand.
They look like they're developed by iphone/android type freaks instead of by people who actually tune cars and need to use and navigate the software whilst tuning
IMO there is no need to keep up with Windows 10, if anything most of those writing tuning software need to avoid it like the plague.
Maybe they'll try and have different software for different tuners. A dumbed down simple colourful option for those who dont know how to tune but heavily restricts options for safety, and a fully functional version for those that do and dont want hindered by the software.
On all the ecu's I've used, usually the best software to work with looks like the most primitive on screen.
Why would you avoid windows 10? It's the current mainstream OS and will be on he majority of computers within the next 12-24 months. It pains me having to run a crap laptop for tuning to ensure the tuning software still works.
Personally I run it at work, home and on my mobile with no issues.
The issues you mention above it bad UX.
Why would you want it for tuning a car when no software is ever designed around it ? Using the latest Windows is the very way to make a lot of ecu tuning software stop working because it isnt designed for it. Usually comms issues.
If you choose to buy a crap laptop for tuning that's your decision, but has no baring on what is required from a laptop for tuning.
Hell a lot of older ecu's still bloody use serial/RS232 for comms which completely rules out anything modern if that's what you do.
USB adaptors are very hit and miss for for serious work not even worth contemplating.
If they use USB comms less of an issue, although some even though they appear USB still use lots of silly drivers to get them to work.
The best I've used lately is Syvecs which uses LAN, which is pretty foolproof and far faster than the rest.
Some people just like changing Windows versions for the sake of it. For a laptop used for tuning it does absolutely nothing a fully tried and tested version of Windows offers.
As a general rule of thumb, if it works on windows 7 64bit then 99% of the time it will work on w8 & 10. Lack of serial port is the main issue. The o.s. Doesn't cause that, just the proliferation of shite cheap hardware from china.
When will ecus go pure usb like most things did in the late 90s.
Hopefully most ecu makers will wise up and ditch USB too in favour of LAN. USB is a step up from Serial, but still not foolproof and still USB is strangely slow when sending or pulling information from ecu's or dash displays.
And whilst you say it isnt a Windows issue that some hardware/software doesnt work with newer versions....of course it is. Why would they work when they havent been designed to work on the newer stuff, never been tested etc ? You just hope it will work with the new OS, but as anyone upgrading knows, there is always something that doesnt work properly after an upgrade.
Just because Windows claim the new stuff is backwards compatible...doesnt mean they're telling the truth. They just hope or think it's backwards compatible, but quite often it is not the case.
They simply cant test every single piece of software and hardware out there to ensure it will work, so there are lots of assumptions made.
As usual, the topic has drifted well of course, but I'll add my thoughts.
Why should they ?
It's called backwards compatibility, something Bill Gates seems to have forgotten about despite everything he said in the past.
To be fair, many do, but use either the prolific chipset or, more commonly, the FTDI to achieve it.
But, as you say, that's not native USB, just a workaround.
People writing ECU code don't need a really fast serial link, just a reliable one.
And the reliable one has worked for many years.
The tuners, firmware writers etc. don't care what the cable is, they just care that it works.
They probably also prefer the relatively simple data stream of RS232 which is primarily one device to another, not multiple devices.
The good writers/harware suppliers also use CAN or I2C.
Neither are a PC specific protacol but they work well with EMS ECUs.
I'm no expert but I get the impression USB is not really EMS ECU friendly unless you just a cable/chip to convert it to plain serial.
Again, personal opinion,
I absolutely hate W7.
I wouldn't even dream of touching W8, 8.1 or 10.
I had to replace my laptop a year ago and the best buy I could find had W8 pre-installed.
When I first started it up I thought, WTF, I bought a laptop, not and overgrown mobile phone with a touchscreen that doesn't work.
So I upgraded to W8.1 and got another pretend mobile phone with a touchscreen that doesn't exist.
Many mouse clicks later I could get it to almost look like a normal laptop, rather than a mobile phone, but just not worth the effort.
So I bought a new HDD for it and tried to instal XP.....
Abject failure because one of the chipsets on the motherboard requires a driver that has never been written for XP.
So I reluctantly purchased a licence for W7 and installed that, and I absolutely hate it, Bill trying to tell me how I should structure my directories and files and preventing me doing it how I want.
And, because it's a licenced copy of W7 I keep getting Bill sending me pop-up windows offering me to upgrade to W10 for free - 10 million people have.....
Well Fuck off Bill, I don't want to, I will teach myself Linux before I ever install W10.
Or I'll just switch to an android tablet because that will actually have a touchscreen.
And to try and drag it back on topic, TunerStudio, which is obviously built around the MegaSquirt/Microsquirt range of products, apart from compatibility with all the Windows newer crap, has a Linux version, and has an android version (shadowdash) that works on android tablets and mobile phones, and some other developers have additional android applications (ie, MS Droid).
So, leave me in the dark ages with XP and a nice RS232 cable and FTDI chipset.
Because it works.
Rant over.
EDIT - typos
Edited by Rod S on 20th Dec, 2015.
Depends on the manufacturer. If you buy cheap shite then chances are it won't work. Dell provided xp drivers up until the enf of 2013 when support for the o.s.formally ended.
Most mainstream manufactures (HP, Lenovo etc) are m.s. Certified, so just work. If you buy cheap hardware, chances are it's a gamble.
I've heard tales of a usb device test bed at Microsoft. It is essentially a large trolley with every conceivable piece of usb hardware on it, all daisy chained with a single usb cable to the test pc. Every single one installs without issue in a normal windows machine.
As for usb to serial, buy cheep and may as well be wiping your arse with your money.
HP laptop Andy (HP 255 to be precise, so not the top range model, but not the cheapest, but on your list). No XP drivers available so I'm forced to use W7 even with a new HDD.
But my point really was about the backwards compatibiliy.
What is really so wrong about using RS232 to programme a single EMS ECU ?
Windows 7 was an abortion, windows 8.1 is very different from xp ( where i stayed untill forced to upgrade)
But now im used to it i think its brill
I use the exact same ecu software for xp and windows 8.1 the although im sure i run a 64 bit version of tunerstudio now
I have free upgrade to win 10 on both my tuning tablet and laptop but im reluctant because the menu system has changed (again)
For ms3 i also dabbled with bluetooth coms with win xp and an android pad with total success no issues at all
I know you can get bluetooth OBD2 mapping hardware / software so thats another connection method
I'll pick up on this one comment.
People writing ecu code may not need fast data transfer. The person tuning the engine will absolutely want fast reliable data transfer. As you say, even USB can be poor at this, but is a step up from serial....or at least should be in terms of speed. A direct serial port is more reliable though ( not an adaptor )
My biggest gripe with most ecu's is datalog downloading. Most force you to shut the engine down and then take ages via either serial or USB to pull very small files for the length of time taken. In some cases minutes ! WTF !
Syvecs via LAN excels here, no need to shut down the engine or anything like that and all info is pulled in a few seconds at most.
Or if you want to stream data to laptop whilst also tuning you have that option too.
So whilst off topic as far as coil configuration goes, IMO communications, tuning software etc are all vital things to consider when choosing what ecu you might want to use
I missed your rather long post Rod whilst writing mine.
Rs232 is nearly as old as me. Why would manufacturers keep making it? Dialup internet works, but technology has moved on.
Too many long posts now for me to read as my tea is nearly ready. I do disagree about windows 7, it works well for most things, but when the software is old you will struggle to get it working on a 64bit o.s. on 64bit hardware.
Manufacturers at large or EMS/ECU specifically ?
I guess at large because it's a basic comms protocol that is simple and works.
And no backwards compatibility issues with what must be millions of items out there using it still.
EMS/ECUs, presumably, like I said earlier, because it is simple and is all that is needed to load the tables/setting on the ECU.
It wouldn't surprise me if lots of the EMS/ECUs out there that appear to have a USB connection don't simply have the RS232 chip hidden in the case and the drivers loaded with the tuning software.
For more modern stuff, particularly data and control as Stevie mentions, there are other protocols. I'm not familiar with the one Stevie mentioned but the obvious one to me is CAN which is pretty much an automotive standard (because it is very tolerant of noise) and used by pretty much every OEM now to link all the various ecu/microcontroller modules dotted around a modern car.
So, whilst considering choice of EMS/ECU it's expandability is worth considering. CAN (the one I'm familiar with) is fully integrated into the Megasquirt range from V2 onwards and is used by myself and many others.
There is OBD2 as Brett mentioned but I think that's primarily for diagnostics.
Another, less common but used by Alan To (14point7) and Jean for AFR digital data and displays is I2C.
(I also use it for my AFR readings so am quite familiar with it).
You say, quite rightly, technology has moved on, but if you take my example above of AFR data collection/display, the majority of wideband controllers are based around a 0-5V analogue output and most EMS/ECUs expect a 0-5V input.
Using an analogue signal can be quite inaccurate because of noise and ground offsets.
Probably the most widely known manufacturer of wideband controllers that do offer digital data for EMS/ECUs that can accept it (or PCs/laptops for logging) is Innovate.
And the data protocol they use is, guess what, RS232.
They just use small 3 pin jack plugs rather than large DB9 connectors, but it's still RS232.
The only one I know of that uses something more "modern" is the 14point7 stuff.
There may be others but I only know of that one because I use it alongside some of Jean's stuff and some of my own.
So way off topic of choice of coils but something to think about when chosing your EMS/ECU is most certainly expandability and future proofing.
(sorry, another long post).
I've seen this as a good thing, it's given me something to read.
Back to the original topic, there is a UK supplier that will build you exactly what you need in whatever configuration, but you will need to move up the MS model range to at least MS2:
http://www.extraefi.co.uk/products/MS_All_products.html
The Microsquirt, being a cut down Megasquirt, will not do the coil configuration that you wish to use without modification. The Microsquirt is intended for use where the builder wishes to expand it to their own purposes.
As for tuning, I thought that we were all going cable free these days?
Is this not just rs232 over bluetooth though or is it a different protocol?
I'm using RS232 over bluetooth but it is perfectly adequate for what these days is a minute amount of data.
I also have USB connectivity, but I don't know if it is RS232. I just need to know that it works and is reliable, which it is.
True with the wireless, the last day at the dyno on my car was all Bluetooth, and it never missed a beat, I was impressed with all the noise around.
Just RS232, on an average Megasquirt at least, as the bluetooth adapter is usually plugged into the DB9 socket.
Whether other EMS/ECUs use some newer protocol over bluetooth or not, I simply don't know.
Ironically, on my MS2 at least, the speed of data transfer for logging is not limited by the use of RS232, but more the amount of hardware and the older firmware that I use.
The I2C connection that I use for digital AFR readings and digital displays is, however, incredibly fast.
So sometimes progress is worthwhile but my setup is quite unique.
EDIT - typo.
Edited by Rod S on 21st Dec, 2015.
monsterob
Member #: 11029
Crewe
i had one of Phils extra efi megasquirts for my vauxhall based haynes roadster i got it all wired up and running but thats as far as i got before the kids and job took over. Few teething issues that did not manifest on the jimstim but that were only apparent on the vehicle two trips back and a trigger wheel setup before we found out.
Outside the box
