Home > Technical Chat > Example Turbo Build for others to follow!!!
Can we have more videos of Victoria? she looks impressive
On 30th Sep, 2014 slater said:
Theres not an easy injection route using the 5 port head. Turbo or not.
That is a missguided statement..........
I realy am surprised at you Jim, I didn't think you were interested in short skinny flat chested women........
True, but it is the general consensus.
It's more to do with the individuals general understanding of fuel injection and the peculiarities of 5 port application than the problem itself IMHO.
Agreed.
Agreed.
What I would add is that very few actually have the necissary dual widebands installed on a turbo 5 port head to actually see what is happening because it's quite complicated to make a dual wideband setup work on a turbo install because the LSUs are pressure and heat sensitive (pressure before the turbo being the accuracy factor, the heat will just shorten their life, but if they are subjected to pressure they will just read wrong).
I can count on the fingers of one hand the people I know who have installed dual widebands on a 5 port turbo.
There may be others but, if so, they keep the data to themselves.
It's not so much the fact that people do not fit the twin widebands, but the fact that they do not understand the need and what to do with the data once they have it. IMHO.
slater
Member #: 1291
Suffolk / Birmingham
All sounds very easy guys!!
It is easy, if you understand the issues and how to deal with them.
People on here these days do not even understand what constitutes as "technical" input in this section.
Change the record Paul.
Andy,
I thought you were going to put twin widebands on your "gaychager" setup ???
I seem to remember it from previous posts of yours but I may be wrong.
An SC vs TC setup will be very different but any such data would be useful, if you are prepared to share and post it.
Otherwise "change the record" kind of comments don't really add to data in the "technical chat" part of the forum.
Just my opinion.
I sold the second wideband in the end as a) I was skint and b) my offer to do so got pretty much zero response.
My comment is more around MS Siamese based injection being the only way to properly inject an A Series. Well, in my opinion, it's not. There are plenty of setups out there that will get you 95% of the way there and be good enough for the vast majority. I'm not aware of anybody running an injected 5 port that has suffered major engine damage due to a lack of port injection.
So where above did I say it was?
I'm very concious of the alternatives and that is why I have not promoted port injection as the only way to do it in a long time.
Not from me, I remember saying I would like to see the results but I can see where you are coming from if no-one else was enthusiastic.
My comment is more around MS Siamese based injection being the only way to properly inject an A Series. Well, in my opinion, it's not. There are plenty of setups out there that will get you 95% of the way there and be good enough for the vast majority. I'm not aware of anybody ever running an injected 5 port that has suffered major engine damage due to a lack of port injection.
All I have ever suggested is that, for PORT injection, you need an ECU that can vary the timing and pulse widths between inners and outers. That is exactly what Rover did with the MPI.
For those using a batch type wet manifold system (aka an electronic carb) I don't doubt for a minute it will produce better results than filing needles on SU carbs.
My comment(s) remain, no-one has yet to show any AFR data (between inners and outers) on such a setup.
If you really want to shoot me down in flames, just say numerous members on TM have destroyed pistons with a carb and no-one yet has with efi on a 5 port and most of the efi setups are wet manifold.
The trouble is lack of data for the alternatives.
It's as much the tone of the posts as the content. Being made to feel inferior on a fairly regular basis isn't particularly pleasant...
I'm in Andy's "Gay" camp.. and I'm struggling to get the car running as well as it did on a carb.
I guess a lot of this is down to setup and tuning on the car. There aren't a lot of "base" map's to start you off and mapping a car from scratch to cope with the all of the road conditions that you find, takes a load of time.
I also think there are limitations of the SC 5 port kit when using it on this kind of setup. For example you don't seem to be able to control the injectors separately, but that might be my simple understanding.
Anyway I have stuck the o2 sensor this time in the middle branch using a Maniflow manifold, I could stick a standalone 02 up the pipe but you cant get much reliably at the lower end of the throttle scale as it seems to suck in air from the outside.
I guess Andy would have had the same issue as the SC ECU doesn't come with dual support so trying to match the data afterwards would be a little difficult. Plus the data logging on the SC ECU seems to be shit. I mean there is a sequence to saving the file that if you don't follow it doesn't capture anything.
I could stick a boss on the inner branch of the manifold when I pull the engine, but I'm not sure I see the point if the data is logged on two separate pieces of software.
Anyway I have thought about dumping the setup and switching back to a carb but, I saved two tanks of fuel going to Combe and back this year over the Carb setup. So its got to be worth another year of attempting to get it running correctly….
Maybe I should buy some of those expensive injectors and drill four extra spark plug holes :)
Anyway we jumping all over the OP thread.
Just to add if I can get the data I'm more than happy to share it. just don't know if I can get it out in the first place... Maybe two computers that I video on the rollers :)
Edited by gr4h4m on 3rd Oct, 2014.
True, I'm quite happy if you want to start a new one wrt supercharged injection but I'll reply here in the meantime.....
I would be very surprised if the SC ECU can't look at two widebands. That's fairly straightforward (just adding a couple of extra components) on the MS2/3 which most people would consider to be "cheap and cheerful" - wrongly I must stress but it is a common perception.
It may be on the SC it has to be setup as an analogue input or something, I doubt if SC would expect you to have to do any DIY like we do with an MS.
I've never used the SC kit but I've seen the hardware when JK showed me around their place a while ago and it looked very well designed/built.
I've never tried the software (obviously) but I can't deny that you, Colin and Tom have all said pretty much the same about it.
Good, all my comments on this subject have been trying to say there is a very limited amount of real data on the AFR split, I don't think any yet on a wet manifold type setup, and the data from the few port injection setups just shows that if you have an ECU with the ability to alter timing and/or pulsewidths between the inners and outers, it's pretty easy to make them the same.
Hopefully there is an easier way for you than video'ing two PCs.....
EDIT - just had a look at SC's site and found this page
and, assuming you are (both) using the Typhoon, whilst it only has one dedicated wideband input (strange as the other versions have two), it has three linear analogue sensor inputs (the line above in the chart).
Just use one of those, not for any engine control, just to log the data. All widebands that I know of will give a 0-5V linear output over a given AFR range irrespective of any more fancv stuff they might do.
If the SC software is "reasonable" you should be able to define a scale of AFR for the 0-5V (the ratio will be in the WB instructions/manual).
Edited by Rod S on 3rd Oct, 2014.
PhilR
Member #: 10034
Birmingham
When I knew I wanted to go turbo, the first thing I did was build an MS2 while my SPI was still in the car. I wanted to learn about fuel injection with a non-turbo engine as it would have been too much to pick up all at once.
I had intended to run a single 02 sensor on a mild 998 turbo. The project has taken a turn and will now be a 1293 turbo that is a few months from completion, so I need to rethink my solution very shortly.
I can't see (don't understand) any reason why single injector wet manifold is any worse than a carb. Given that carb turbos can make big numbers, I'd much prefer to stick with the single injector for as long as possible than do port injection, simply because this would be an easier route for me.
1) Is my plan feasible?
2) Would data from twin widebands in this configuration be of use?
As I said above, it probably isn't any worse (provided you run four squirts per cycle).
On a technicality, the only thing that makes it worse is that injection is a series of discrete pulses whereas a carb is continuous mixing - discrete pulses may be more likely to get to the wrong cylinder. However, the ability to control everything on the fly, compared to filing needles, changing dashpot oil/springs, adding "tee piece" tricks, etc, etc, probably far outweighs that technicality. But see below...
Only to see what is actually happening.
Unless you get really inventive there is little you can do to change the relative AFRs on a wet manifold setup.
All I have ever tried to say (and apparently been mis-understood) is no-one yet has done this to see how good/bad it really is.
I'm fairly confident that I could get a wet manifold setup to give acceptable AFR distribution with the MS2 in sequential mode, the correct size injectors and injection strategy.
After all, its much the same as my port injection setups with the injectors set a bit further away from the inlet valve.
Just saying *smiley*
We think alike.... hence my "unless you get really inventive".
I think it would take a lot of experimenting to get right but the starting point is two widebands.....
Not that I'll try it.
My latest port injection setup cost less than £1000 including the 2 widebands *smiley*
PhilR
Member #: 10034
Birmingham
Thanks guys. At this point, 2 sensors sounds likely for my build. I'll post again closer to the time
How much does a ready built MS3 suitable for siamese port injection cost these days? excluding the widebands and associated sensors..... just the black box?
You don't need an MS3, in fact you can't run the siamese code on the MS3, the variable injection timing is done in a more generic way with MS3.
The siamese code (as it is usually known, it's actually now just an option in the MS2-E code) is specific to MS2.
I haven't a clue how to answer your question Colin, you well know that most of the MS range is predominantly DIY.
Yes, you can buy it pre-built for a lot of applications but for the A series running the siamese code, especially if you want staged injection, I doubt you will get it off the shelf.
The off the shelf installs are more down to mainstream cars.
I could build an MS2 siamese (using the standard mainboard which I hate, but mostly Jean's boards) with staged injection for less than £300.
I can add two widebands using 14point7 stuff and Jean's IOx (which gives digital AFR inputs, not 0-5V) for pretty much the same again.
Add two more widebands (ie, both outers individually, inner and after turbo) for not much more.
Biggest cost of such a setup is the LSUs themselves.
BUT, and a really big but, that is a lot of DIY.
You can't really compare what is possible with Megasquirt to off the shelf systems.
£550 - £600 ish.
Just wire it in an go *smiley* You probably wont even need to open the case.
Edited by Paul S on 3rd Oct, 2014.
Users viewing this thread: none. (+ 4 Guests) <- Prev   Next ->
