Page: |
Home > Technical Chat > Tie bar droppers/ Anti-dive brackets????? | |||||||
224 Posts Member #: 9987 Senior Member Amsterdam |
15th Jan, 2014 at 06:55:25pm
The Owens tie bar / rod joint seems a sturdy piece of kit...
326 Posts Member #: 1323 Senior Member |
15th Jan, 2014 at 08:49:36pm
I've used Anti Dive on all Front engine RWD Hillclimb cars to National Championship winning level .
151 Posts Member #: 5593 Advanced Member Taunton, South West |
15th Jan, 2014 at 09:53:29pm
Thanks, that old thread is useful, good link Paul :)
Edited by Mowen123 on 15th Jan, 2014. |
15th Jan, 2014 at 10:04:13pm
oh just checked Wil's website and it appears i'm confused. It's the other way round, yellow dots on the front and softer red dots on the rear. now i'm confused |
16th Jan, 2014 at 08:02:09am
Because of the way the top arm locates with the spring, as you lower the front the spring rate drops. I had to use the yellow dot on the front to keep roll in check.
17th Jan, 2014 at 01:23:15pm
Right ok, I didn't know that. Is there a reason for not using yellows on the rear as well? I know the rear ARB would limit the roll, but would yellow dots have complimented it?
On 16th Jan, 2014 wil_h said:
Because of the way the top arm locates with the spring, as you lower the front the spring rate drops. I had to use the yellow dot on the front to keep roll in check. I also ended up fitting ARBs to help. for a race car it's still pretty soft. Although my car is significantly ligher than a road car. |
25 Posts Member #: 10295 Member |
13th Mar, 2014 at 11:08:53pm
Any updates on this? does anyone know how far (mm) to lower the ball joint and caster arm pivot point? - interesting thread would love to hear some more feedback |
Page: |
