Page: |
Home > Show Us Yours! > Chalkie's Sc Small Bore Build. | |||||||
3rd Feb, 2015 at 09:33:19pm
A couple more braces before you cut anymore ( perhaps towards the gearstick / handbrake area), then tack them all in and recheck the door gap.
Edited by PhilR on 3rd Feb, 2015. |
3rd Feb, 2015 at 09:36:58pm
Phil door gaps fine keep dropping do in every now and then but will brace it abit more tomorrow props do the other door aswell then cross them over |
3rd Feb, 2015 at 09:43:54pm
Didn't see you're last post about the sub-frame. are you doing a half floor of just the front footwell?
3rd Feb, 2015 at 09:52:01pm
I gotta do Inner flinch, half floor, rear subframe mount and door step
4th Feb, 2015 at 06:24:28pm
Got alot more bracing in today
6th Feb, 2015 at 09:29:03pm
So is this enough bracing now? gotta add one or 2 more but is this good enough?
13th Apr, 2015 at 08:15:12pm
Evening guys
4890 Posts Member #: 1775 Post Whore Chester |
13th Apr, 2015 at 08:23:23pm
IMO the 274 would make a better boosted cam.
4304 Posts Member #: 1321 Post Whore Wiltshire |
13th Apr, 2015 at 08:56:15pm
Ha, loving the bracing. Got a bit out of hand with the welder? On 7th Oct, 2010 5haneJ said:
13th Apr, 2015 at 09:15:13pm
On 13th Apr, 2015 gr4h4m said:
IMO the 274 would make a better boosted cam. Just an observations but won't your centre strap needs to be wider and have a groove machined in or tangs to hold the thrusts in place? Mine does. Its the one that came from Minispares and its what the shop said they did to there mini engine what near enough same spec as my Na run will be but you think its wrong? and can never have enough bracing haha. |
13th Apr, 2015 at 09:47:48pm
Have a look at Pauls thread it shows the groove needed and iirc the 1275 and 998 straps are different I run a supercharger and I don't care the TB is on the wrong side.
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
14th Apr, 2015 at 05:44:28am
There's several ways to do it. I've filed a groove on the block before and put them in upside-down. |
14th Apr, 2015 at 06:52:55am
This is a 998 block and a 998 centre main. I'm confused :( |
14th Apr, 2015 at 06:52:57am
14th Apr, 2015 at 10:16:53am
There's a tang on one half of the thrust bearing that locates in a slot on the cap. When you machine a 998 cap down you have to delete that slot, so the bearing is now free to rotate more than intended. This isn't a problem with a 1275 cap as don't machine the slots out of the cap.
On 14th Apr, 2015 slater said:
There's several ways to do it. I've filed a groove on the block before and put them in upside-down. Bloody excellent idea. I think that's how I'll be fitting mine next time. |
17th Apr, 2015 at 08:39:18am
i was also advised to use the md274 cam from the few short runs ive had im impressed with the off boost torque if it was rubbish id certainly know running the clubman ratios and 2.95 FD low end torque is where its at for me then boost takes over for the top end
17th Apr, 2015 at 11:18:21am
Will the 274 be okay on Na set up though I'm bedding the engine in na first then going boosted |
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
17th Apr, 2015 at 12:18:45pm
On 17th Apr, 2015 Chalkie said:
Will the 274 be okay on Na set up though I'm bedding the engine in na first then going boosted IIRC the 274 is very similar to the mg metro cam so it shouldn't be a problem |
2nd May, 2015 at 07:56:39am
I have an update!
2nd May, 2015 at 09:50:14am
I've done some quick calcs.
2nd May, 2015 at 06:45:10pm
On 2nd May, 2015 Paul S said:
I've done some quick calcs. Assuming 1030cc engine, 40 Deg C after intercooler intake temp and 0.7 Barg boost, then you need to run the blower rotors at 2.085:1. That will run the blower rotors at 15,637 rpm at your 7500rpm engine limit. As the blower is internally geared at 1.93:1, your pulley ratio needs to be just 1.08:1. So the blower pulley will need to be nearly as big as the crank pulley. How big is your crank pulley? Unfortunately I don't know how big med's Bottom pulley is as haven't brought it just yet, Unless I use your idea of using a smaller pulley inside the oringal pulley using a longer bolt aslong the clearance works with the rad mount (mod can be done i got 3 mounts) |
2nd May, 2015 at 08:06:21pm
Paul if i have worked this out right I hope
144 Posts Member #: 10828 Advanced Member Rainhill, Merseyside. |
2nd May, 2015 at 08:07:39pm
Very interesting build. I wonder if the fuel injection will solve the supercharger's drinking problem. On 18th Nov, 2014 D4VE said:
went down to my local hydraulics place and he gave me a suitable replacement larger nipple |
2nd May, 2015 at 08:32:16pm
On 2nd May, 2015 Anthony30 said:
Very interesting build. I wonder if the fuel injection will solve the supercharger's drinking problem. Ill be using like 850 or 1000cc injectors so I don't know what fuel will be like just yet but we'll see and thanks bud |
3rd May, 2015 at 09:08:20am
On 2nd May, 2015 Chalkie said:
Paul if i have worked this out right I hope taking a standard 998 damper pulley I have 120.73mm and current SC pulley at 52.95mm so 120.73mm @ 1 rotation = 52.95 @ 2.28 rotations In your calculation your saying I need 120.73mm : 1 rotation BP to go to 1.08 ratio on the SC Pulley that would make the pulley 121.55mm so that would then roughly if ive worked it out right 120.73mm @ 1 rotation = 121.55mm @0.993 Rotations so at 7500 rpm that works out on SC pulley to do 7450.63RPM So that is my go at maths and using a site for pulley sizing just to be pedantic all measurements taking at 20degree's Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
