Page: |
Home > Show Us Yours! > Josh's turbo 1098cc carburetion sucks lets try EFI | |||||||
22nd Nov, 2012 at 09:52:43am
Get the crank key fixed, you'll need an accurate timing pulley for MS.
22nd Nov, 2012 at 10:54:44am
For the crank, if the keyway is goosed it usually means the pulley got loose somehow and will no longer be a tight fit on the crank tail. You need to have a good fitting pulley before spending money on repairing the keyway.
22nd Nov, 2012 at 11:41:18am
Paul
22nd Nov, 2012 at 12:21:34pm
You need to understand the MS architecture.
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
22nd Nov, 2012 at 01:51:34pm
Do NOT use those exhaust valves in a turbo engine. Get some 26.5mm from Minispares.
23rd Nov, 2012 at 09:46:21am
vegard i witch valves are they? i cant find any 26.5mm ones ? you mean the turbo ones? AHU1976
23rd Nov, 2012 at 10:17:14am
You are missing the main board.
26th Nov, 2012 at 06:00:30am
ohh duh.. thanks paul
26th Nov, 2012 at 12:09:11pm
http://minispares.com/product/Classic/Engi...classic/exhaust valves.aspx|Back to search On 13th Jul, 2012 Ben H said:
26th Nov, 2012 at 10:37:45pm
Vegard thanks mate what intake would you recommend?
27th Nov, 2012 at 10:23:47am
On 26th Nov, 2012 Turbo This.. said:
Vegard thanks mate what intake would you recommend? http://minispares.com/product/Classic/C-AEG588.aspx ? Yup, those are nice valves. The reason for me saying this, is that the standard A valves are so extremely soft. A+ valves are better and could possibly withstand a lille turboing, but new performance valves for Minis are dirt cheap. I'd fit bronze guides at the same time. On 13th Jul, 2012 Ben H said:
27th Nov, 2012 at 10:30:13am
just had a thought whilst doing an oil change on the work ute today.. the filter (ryco Z68) looks the same as the one i run on the mini (ryco 418)but its longer.. so i checked and yep its the same from what i can see.. it spin's on the mini housing and the seal is the same size now my qustion is the longer one should have more filtering ability? ie pass a larger volume of oil before the internal bypass acetates? reason im looking at this is i will be unseeing a no bypass filter head i have looked to see what filter will fit and have no internal bypass but flow a lot of oil and cant find much at all jut wondering if anyone run a no bypass oil filter and housing ? |
27th Nov, 2012 at 10:52:01am
already have some bronz/mag/alu bullet ones waiting = ) didnt know the a ones where soft vs a+ ones the rim flow ones look grate but is it worth the cash? Also the s6 ones that med sell same deal bangfor buck? Surly the life span is less on the med s6 onges due to smaller contact valve to guide im also guessing the heat transfer is less to? Edited by Turbo This.. on 27th Nov, 2012. |
27th Nov, 2012 at 03:57:18pm
28th Nov, 2012 at 06:20:37am
So thats yess the rimflow n S6 ones are worth the cash for a turbo build and yess the heat transfer and wear life is not so grate on the S6 ? Anyone had experince with any of them? Can a small bore turbo run flush and flat tops given the head has been pulled right out to 31cc for 9.5:1 or 32cc for 9.25:1 just an idear lol
Edited by Turbo This.. on 28th Nov, 2012. |
28th Nov, 2012 at 01:09:40pm
On 27th Nov, 2012 Turbo This.. said:
Also the s6 ones that med sell same deal bangfor buck? Surly the life span is less on the med s6 onges due to smaller contact valve to guide im also guessing the heat transfer is less to? Yes. I don't think you can get small bore S6 valves. On 13th Jul, 2012 Ben H said:
4th Dec, 2012 at 09:55:54am
well my replacement crank showed up today so hoping its in a useable concision..
6th Dec, 2012 at 10:52:14am
i have been walking past the mini a few times and lifting the bonnet off i keep saying i should put a big front mound radiator and charge cooler in with some alu boxing/air guide bits to force the air throw so what im getting at is.. dose anyone know anyone that's done this sort of thing with a fixed steel club man fronted mini ? there is plenty of room to do this i think so im keen to have a go also as far as cooler designs go whats best delta fin? tight fin pack lose fin pack? cheep or 5 times the price quality made?
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
6th Dec, 2012 at 11:03:02am
Have a look at my build (1275gts) for front mount rad installation and ducting. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
19th Dec, 2012 at 01:55:34am
Nice build mate i think i will try do some alu ducting of some sort to fill the gaps between the coolers and body so the air has to pass throw rather than around my only concern is this could make a vacuum behind the coolers sucking crap up from the road?
28th Dec, 2012 at 09:43:23am
well not much had been going on as im two states from the car for a month over Christmas so ive started restoring some wheels for the mini that i had a the parents place
140 Posts Member #: 10115 Advanced Member Sydney, Australia |
28th Dec, 2012 at 10:07:05am
nice mate, they'll come up looking great with a re-paint and cleaning up.
28th Dec, 2012 at 10:26:42am
thanks yeah i hope the come up near new there might be the odd mark as i don't want to take too much off to get that nice finish it will be a happy mix i think between strength and marks.. has any one had experience with this sort of thing?
28th Dec, 2012 at 01:55:58pm
I havent physically done it myself but a mate has cleaned wheels up, and it is a fine line between strength and marks.
1st Jan, 2013 at 09:38:01pm
me two braad trouble is time needed to get that finish running the both on a 10 minute duty cycle to reduce the effects on the poor compressor also id like to keep them original as passable |
Page: |
