Home > Show Us Yours! > K1275 RS revisited
On 6th Aug, 2012 robert said:
On 4th Aug, 2012 matty said:
Nice work Colin. Another 16v for group D2 next year! *happy*
fixed that for you matt*happy* *wink* *wink*
lets not start that little debate again. Anyway, where would that put Nic these days?
you lost me colin *smiley*
Home!!!
Chalkie
Member #: 9764
Northamptonshire.
Looks cool dude!
bennyy
Member #: 9037
Doncaster, yorkshire
Clooks awesome, even the two tone subframe... Lol
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Bling ... Colin did you train as a gynaecologist?
Carl S
Member #: 1761
Stalker
Looks great Colin :)
maccamcvey
Member #: 6673
Worral Sheffield
looks very nice mate, with your water feed to the turbo is there there anything to encourage curculation? I was planning to take the hot side back up to the stat houseing hoping the hot water will go up. yours looks much neater but is there something I am missing?
The turbo core is canted slightly towards the hot side. Cool water from the block rises up to the turbo water jacket inlet which is lower than the outlet. Th eoutlet is connected directly to the rad header tank. During engine shutdown and heat soak, the water in the turbo core gets heated. Hot water rises, heat travels from hot to cold, the rad is the coldest part of the system. This creates a thermo syphon as the hot water travels towards the rad, it draws cooler water from the block. That is how it works on the Saab. No need to complicate things installing pumps. I intend to install a delay off relay on the electric fan, that is energised on key off, to help kool the turbo during initial heat soak
maccamcvey
Member #: 6673
Worral Sheffield
yea I intend to have a similar set up, not planned any fans yet, it was the two hoses on the back of the block that confused me...
Those are oil drains from the head *wink*
maccamcvey
Member #: 6673
Worral Sheffield
arrrr it all comes clear now... ish *wink*
Colin where does the drain from the turbo go?
It goes into one of the holes I drilled in the tappet chest in the same manor as the head drains. I did think about putting it in somewhere lower down, but it was too far from the turbo in my opinion
braad
Member #: 10115
Sydney, Australia
The car looks good
That is freaking ingenious! I had never thought of applying that to a car
OK so it has been a while, but things have been progressing, maybe not as fast as I'd have liked, but its slowly coming together. At least doing it this way I am totally concentrating on the jobs in hand rather than rushing it through and not bothering with some stuff just to get it on the road. I am pleased at how well its all going back together, thats mainly down to all the preperation, thought and 'design' over the last three years.
So here is the story so far picking up where i left off the last time.
Cleaning up and painting the engine bay. We were running out of time when we painted the body, so I said just leave the engine bay and I'll do it at a later date. Notice the hole in the inner wing for the intercooler *wink*
The new choke control. also known as 'boost control' *happy*
The engine in its home at ong last
Excellent bonnet and grille fit/ alignment :)
Not far off looking complete
Downpipe. The original idea as can be seen here was to have the downpipe in two pieces with a slip joint behind the engine, but after fitting it to the car, and seeing how much space i still had left behind the subframe, i reckoned i could get it in and out in one piece, so after a tried and succeeded, i bust out the welder and welded up that slip joint *happy*
ECU and engine wiring including the charging and power distribution circuits
Tunnel heat shield with added fibreglass over the Catalytic converter
Exhaust construction. some might recognise the back box, it was Benny's. Ive added an 18" mid section silencer and a 200 cell sports cat. Should be nice and quiet *happy*
Edited by Sprocket on 21st Mar, 2013.
Billus89
Member #: 8931
Looking brilliant! Someone has been busy *Clapping*
Chalkie
Member #: 9764
Northamptonshire.
Looking good!!
adrian
Member #: 2726
wakefield
Top work. Looks brilliant mate :)
Nice work mate. Looks great.
I love the relative factory look of this build
Carl S
Member #: 1761
Stalker
Excellent :) Almost there now!
Coming along nicely. Nice attention to detail as always.
Have you got some plans in mind for IC ducting?
kappa
Member #: 9854
Hounslow, Middlesex
Looks amazing Colin, great work.
May I ask colour whit is this?
Nice work Col. *smiley*
Users viewing this thread: none. (+ 3 Guests) <- Prev   Next ->
