Home > Show Us Yours! > My project turbo racer now going Jap
adamt
Member #: 9181
Rhoose, Cardiff
Small update.
Pulled out the old 1275 and front subframe
Got a Suzuki bare frame from Allspeed because i didnt fancy making my own from scratch. Just got to weld my own mounts on it. Really impressed with the build quality.
Had to cut off the old engine steady brackets so the plenum would clear.
As it will sit in subframe. There are little things that need to be changed such as the gear selector arms on the gearbox need modifying because they touch the suspension tower, but it seems quite straight forward at the moment.
Im still waiting on a back gearbox mount, then once i have that i will be able to weld the mounting points to the subframe. I have trial fitted the front end and at the moment it looks like i will have to open up the grill aperture slightly to clear the turbo. The rad might be a problem but im hoping i can fit a Mini 2 core rad on the right hand side.
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0
mercenary62
Member #: 9937
nice work im still welding up my shell mate ,youve got a gr8 project there
give em hell
giacomo
Member #: 6996
any updates?
giacomo
Member #: 6996
ignore that! great build matey :) friend of mines just started his build, he's hoping to keep it in a round nose too
adamt
Member #: 9181
Rhoose, Cardiff
Subframe is now finished finally. It was a pain in the arse. Lost count on how many times ive lifted the engine in and out to make sure the mounts were right, but im happy with the end result. There isnt much engine movement on the rubber mounts, which is good because the plenum is so close to the bulkhead. But to be sure i will be replacing them with poly mounts and possibly some extra steadies.
Next job is to mount the gear stick housing in the car and route the cables through the bulkhead, then modify the arms on the gearbox.
Few pictures
Mount in progress
Had to move the crossmember up to clear the gearbox
Trial fitting the front
Looks like the turbo will have to be poking out the grill a little :)
Rear gearbox mount made from scratch because original position couldn't be used
Finished subframe
And finally with engine in
mini.cooper998
Member #: 3772
Wigan
amazing build and great quality, good to see built not bought looking so good. I have a question, what paint did you use on the underside and interior, looks very nice and smooth also how was it applied.
ANdy
adamt
Member #: 9181
Rhoose, Cardiff
Thanks mate. For the underneath i used normal rattle can primer, then stonechipped it and then i brush painted over that with red hammerite. I was quite surprised with the finish tbh. The inside i just used rattle cans because i thought if it gets damaged it would be easier to touch up.
mini.cooper998
Member #: 3772
Wigan
looks very good for rattle cans
adamt
Member #: 9181
Rhoose, Cardiff
Yesterday i welded a plate in where the original mini gear stick went through. Then today i have mounted the starlet gear stick housing inside and routed the cables through the bulkhead to the gearbox. The brackets are made from aluminum then bolted these to the side of the tunnel. I have also modified the selector arms on the gearbox (pictures to follow) and its bloody tight.
Piccys:
Rick.SPI
Member #: 8027
Looking good so far mate :)
adamt
Member #: 9181
Rhoose, Cardiff
Cheers mate. When do you think yours will be finished?
Rick.SPI
Member #: 8027
Deadline is just after xmas for a french roadtrip. Failing that itl be asap after what about you mate?
The wiring is what im fearing the most
adamt
Member #: 9181
Rhoose, Cardiff
The road trip sounds good, should be a laugh. I'm planing to have mine running by Christmas on the stock ecu and stock intercooler. Then I will get a programmable ecu, bigger intercooler and different exhaust manifold. Then get it mapped and up the boost a little :)
Yeah I'm not looking forward to the wiring either
adamt
Member #: 9181
Rhoose, Cardiff
As promised some pictures of the gear cable arrangement at the gearbox end. Today ive had to re weld the bracket differently because there was too much slack in the cable. Which resulted in the gear stick having 1st where third would normally be and third where fifth would be, but its all sorted now thankfully.
Bracket for mounting cable to gearbox, original one is on the left and one i modified on the right.
Selector arm that does left to right on gear stick. Had to cut and re weld it so the arm was further in to clear tower on subframe. This then meant i had to make it drop lower so it doesnt come in contact with the other selector arm.
Gearbox with finished bracket and cables bolted on, not much space!
Scudy23
Member #: 10087
Very wet south wales
Thats some very good work, what would be the plan with the turbo out front ?
Are you selling your mirage mani as well off the other engine ?
adamt
Member #: 9181
Rhoose, Cardiff
I have now decided to relocate the actuator which means hopefully by spacing the grill a little it will fit nicely behined.
Sorry but ive sold all my turbo bits now, with the exception of a 1293 block and crank
Craigie-B
Member #: 9468
Wootton Bassett
This is cooooool :)
Rick.SPI
Member #: 8027
Goo progress going on mate. Your gunna beat me to thr finish at this rate.
adamt
Member #: 9181
Rhoose, Cardiff
Got round to fitting the front end properly yesterday so I know how much space I have for things like the radiator. The one in the picture is an mpi one, not sure whether to use it or get something better. Also don't know where to put the intercooler as I don't want to drill holes in the bonnet.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Have a look at Matty's build thread for intercooler placement.
"Try to take over the world!"
adamt
Member #: 9181
Rhoose, Cardiff
Have you got a link? I've had a look before but couldn't find it
danb41
Member #: 9285
Oxfordshire
That's a crammed install, keep up the good work!
Here's a link. There are more photos in there somewhere.
http://www.turbominis.co.uk/forums/index.p...d=169346&fr=500
love what your doing keep use posted
vegar
Member #: 189
Are you running the turbo out of the grille?? Thats a bit different I thonk :)
www.shag.no
adamt
Member #: 9181
Rhoose, Cardiff
Yeah i thought i would get away with relocating the actuator and spacing the grill but it does stick out a fair bit. looks like i will be removing a few slats from the grill now lol.
Also tonight i have started making the bracket for mounting my alternator. I'll get some pictures when its finished tomorrow.
Users viewing this thread: none. (+ 2 Guests) <- Prev   Next ->
