Page: |
Home > General Chat > stone guard / chip | |||||||
23rd Dec, 2011 at 01:04:55pm
Andy you can borrow my air fed mask if you like.
23rd Dec, 2011 at 01:10:18pm
Thanks tom. i may give a shout when i get that far. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
23rd Dec, 2011 at 02:07:58pm
What size/power compressor is the minimum for painting and running an air fed mask? On 11th Feb, 2015 robert said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
23rd Dec, 2011 at 02:15:46pm
size just means how many times you will have to stop between spraying for the pressure to build back up but id go for at least 100 150 ltr tank, not sure with running the mask as well but i only use a fine dust mask when spraying Edited by wng691s clubby on 23rd Dec, 2011. Done now needs redoing lol |
23rd Dec, 2011 at 02:29:05pm
I guess its not the end of the world for primer etc underneath the car On 11th Feb, 2015 robert said:
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
23rd Dec, 2011 at 02:32:26pm
Two issues,
23rd Dec, 2011 at 02:40:19pm
Thanks. That's a bit out of my price range...
23rd Dec, 2011 at 02:42:43pm
23rd Dec, 2011 at 02:46:10pm
Might be worth trying to borrow a couple of compressors if you can andy, im sure somebody can help you out! One for the gun and another for the mask, you can then place the one for the mask out of the way of the spraying. On 26th Jan, 2012 Tom Fenton said:
23rd Dec, 2011 at 02:50:39pm
I've already got a small one, but a small as a die grindercan use more air than it can supply On 11th Feb, 2015 robert said:
23rd Dec, 2011 at 03:08:16pm
Mate i have a small ebay job and it did the job fine in my boot, it was going like mad mind:) If you need a spray gun and stone chip gun, i can send you mine to keep the price down, then john can just bring them back when he is next down this way.
23rd Dec, 2011 at 03:15:53pm
Thanks Simon. I've got a crappy spray gun and don't mind buying a shutz gun, probably be quite useful On 11th Feb, 2015 robert said:
23rd Dec, 2011 at 04:04:15pm
The mask doesn't use all that much air, and remember when spraying you are down on pressure so not using so much volume out of the tank anywhere. My compr is about 10 CFM and copes OK.
23rd Dec, 2011 at 04:28:53pm
On 23rd Dec, 2011 Tom Fenton said:
The mask doesn't use all that much air, and remember when spraying you are down on pressure so not using so much volume out of the tank anywhere. My compr is about 10 CFM and copes OK. Tom, depends on how high you set the flow to the mask - I set it quite high because I wear glasses and they steam up on low flows. It will all be down to individual uses but I would suggest 12-14cfm (and a large receiver) is a good starting point to aim for. Schrödinger's cat - so which one am I ??? |
23rd Dec, 2011 at 05:30:10pm
mine is 1.5hp and a 25l tank. not sure to the CFM. On 11th Feb, 2015 robert said:
23rd Dec, 2011 at 07:58:11pm
The mask doesn't use all that much air, and remember when spraying you are down on pressure so not using so much volume out of the tank anywhere. My compr is about 10 CFM and copes OK. Tom, depends on how high you set the flow to the mask - I set it quite high because I wear glasses and they steam up on low flows. It will all be down to individual uses but I would suggest 12-14cfm (and a large receiver) is a good starting point to aim for. Rod, I am talking from my experience with my own setup, mine is a pro mask with its own carbon filter and reg, so to say you need 12-14 cfm in my experience with my mask and my compressor is not the case.
23rd Dec, 2011 at 08:10:57pm
Rod, I am talking from my experience with my own setup, mine is a pro mask with its own carbon filter and reg, so to say you need 12-14 cfm in my experience with my mask and my compressor is not the case. Tom, just pointing out 12-14cfm is my experience. Mine is a straight air fed mask (no filters) with the flow/pressure regulator on the belt. And I like a high air flow because of wearing glasses. Also I use a high volume spray gun. Every setup will be different but I learnt a long time ago not to scrimp on the capacity of a compressor. Better too much than too little :) Schrödinger's cat - so which one am I ??? |
Page: |
