Page: |
Home > A-Series EFI / Injection > Canems ECU 1380 N/A | |||||||
96 Posts Member #: 7325 Advanced Member |
29th Jun, 2011 at 10:35:55pm
Ill go re-read it all again and try make heads or tails of it. |
29th Jun, 2011 at 11:01:23pm
On 29th Jun, 2011 sturgeo said:
If you haven't already, have a good read of this: http://www.canems.co.uk/siameseports.php If you look at their own log at the bottom of the page, you'll see that the AFRs is not well matched for a big portion of the engine range even though they claim they are balanced. Of course, they don't make the picture very big so you have to look at it carefully and know what you're looking for. On 29th Jun, 2011 sturgeo said:
I personally believe that the canems system can be made to work better than a carb. We personally didn't have much luck with this method but with time working on your injection timing table and on a RR at various rpm/load sites you should be able to do a better job. It'll be better than any wet manifold setup which are about as good as pissing into the wind. You're probably right that this can be made to work better than a carb or a wet manifold. But no matter the amount of time you spend on tuning the injection timing, you will never be able to get the outer cylinder richer. If you were to work on the engine itself to skew the VE such that it matched the fueling then you might get balanced AFRs from the identical pulse widths but even then I'm not sure you could make it work for the entire RPM and load range. Jean |
857 Posts Member #: 1778 Post Whore Northants |
29th Jun, 2011 at 11:30:25pm
I might be mistaken but I think that the graph showing afr's was when using 2 narrowbands. |
29th Jun, 2011 at 11:50:57pm
I might be mistaken but I think that the graph showing afr's was when using 2 narrowbands. The one at the bottom? Then why present it as AFR (which cannot be obtained reliably from narrowbands) and even then the data presented does not back what they claim. I'm not saying that this is a bad product but they make claims they cannot back with data in all the graphs they have published, at least from what I've seen. Their injection method makes for a relatively easy to install and use setup but it does not address all the issues of port injecting a 5-port head. And their claim that it does is misleading at best as demonstrated by their own published data. If even they cannot do better than that then who can? Jean |
30th Jun, 2011 at 08:11:34am
Re. Canems itself, I've had a quick read of their website and it seems it's pretty much the same as the MS2 semi sequential siamese code developed on this site three years or more ago.
30th Jun, 2011 at 08:51:16am
We found semi-sequential to be very driveable, just that the AFRs in the outers were not rich enough for turbo application. Canems have proved with dyno runs that there system is better than a carb, unlike some others that come to mind.
30th Jun, 2011 at 09:55:18am
Quote from the guys at canems lifted from efiminis.
30th Jun, 2011 at 10:36:25am
Ive a few hours free today so Im going to double check all the wiring and hardware to make sure its all good. |
30th Jun, 2011 at 12:09:38pm
All the wiring is fine, so its not a wiring issue. The Airleak is the next thing to look at but I dont have the time today to get under the car.
30th Jun, 2011 at 12:23:10pm
It is extremely unusual for the inners to be lean - with injection, we try to stop the outers being lean....
30th Jun, 2011 at 12:32:15pm
On 30th Jun, 2011 sturgeo said:
Quote from the guys at canems lifted from efiminis. "As for how the car drives when you change the injection timing, Tim Mundy (technical editor of MiniWorld) wrote the following in his product review: "The superiority of the Canems system is demonstrated in full, though, when David switches off the unique fuel timing, the system immediately loses power and becomes a lot less crisp. Switching it on brings relief." This is interesting, as we know a wet manifold can work to a similar performance as a carb, but it can be so wrong that the differance between 'conventional' and the Canems system could be made to look massive. It's interesting to see the differance between inner and outer on the canems, do we have similar info for wet manifold and carb? From my experience with a carb, cylinder no. 1 is always lean, and this is the only cylinder where there is evidence of det and where the head gasket always fails. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Jun, 2011 at 12:55:45pm
The Injection timing was set to 2D and was only timing at Idle. I changed it to 3-D and brought it for a run. There is a improvement, but the inners are still lean according to the sensors, although its not as extreme.
30th Jun, 2011 at 01:09:28pm
We did a dual wideband log on a hif a few years back, the logs must be somewhere on here. |
30th Jun, 2011 at 01:21:27pm
A quick summary of 4 years of testing:
Edited by Paul S on 30th Jun, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Jun, 2011 at 01:37:18pm
Now that is interesting. Certinally the semisequential was significantly worse than the HIF. and the sequentail better. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Jun, 2011 at 01:44:54pm
If I recall correctly we didn't do much config on semi-sequential so what you see there might be the base settings. I'll see if I can find a .msq from that date and see what settings we were using. |
30th Jun, 2011 at 01:51:59pm
I think that the semi-sequential log above is as good as it got.
30th Jun, 2011 at 02:09:48pm
http://www.jaservices.co.uk/photos/Dual%20...20Table%201.pdf
30th Jun, 2011 at 02:26:45pm
I am firmly of the opinion that if you want better fueling than a carb, then there is only one way to do it.
30th Jun, 2011 at 02:52:13pm
I agree with Paul and that is also probably why Canems was able to make the gains they show.
Page: |
