Page: |
Home > A-Series EFI / Injection > Megasquirt modifications for Siamese/ sequential code | |||||||
![]() 6748 Posts Member #: 828 Post Whore uranus |
14th Nov, 2009 at 03:28:33pm
hmmm this is sounding more and more attractive as a way to get good mixture control at al boost levels . i wonder how much it could be done for assembling ones own ecu from a kit and using jaw widebands ..hmm
14th Nov, 2009 at 04:20:41pm
It looks like you've got a very good handle on what's needed to get this to work. As mentioned there might be a couple of things you may want to clarify or revisit but overall it sounds like a good plan. The schedule might be a bit aggressive but that's up to you.
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
14th Nov, 2009 at 04:42:07pm
On 14th Nov, 2009 robert said:
hmmm this is sounding more and more attractive as a way to get good mixture control at al boost levels . i wonder how much it could be done for assembling ones own ecu from a kit and using jaw widebands ..hmm At least then you could concentrate in keeping it in a straight line, rather than fiddling with the MBC and the choke ![]() Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Nov, 2009 at 05:14:29pm
hahahahahaha ...so true
Edited by robert on 14th Nov, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
14th Nov, 2009 at 05:18:58pm
On 14th Nov, 2009 jbelanger said:
It's good to see another player on the team :) To me that's the most important bit at the moment (he says during a break from yet more welding.....) Why are the electronics so easy and the rust so hard....... ![]() Schrödinger's cat - so which one am I ??? |
14th Nov, 2009 at 05:19:04pm
Robert, while the JAW wideband looks good, I've yet to read anything concrete and unbiased on it's accuracy. I've seen some bad data but that was from a competitor so that may be valid or not. And I've seen people claiming that it's great but they were just using it blindly so that's meaningless. So until I see some evidence that it's really all it claims to be, I'd be reluctant to use it or recommend it. However, if someone were to do some tests on it, it would be great because that would make for a nice affordable package. Jean good points jean . i have an assembled jaw at home and a lm1 ,so will do a comparison when i return from vancouver . looks like the minimum cost would be partial kit from diy autotune ,board from jean ,2 jaw's .inj from scrappy and pump/ plenum scrounged made etc .hmm . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
14th Nov, 2009 at 07:20:59pm
Well, While I was out today, the postman tried to deliver My JimStim board and CPU. No one was here to sign for it. So now I have to wait until Monday.
’77 Clubman build thread
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
14th Nov, 2009 at 07:38:37pm
Good to see another person taking on the Siamese port challenge!
857 Posts Member #: 1778 Post Whore Northants |
14th Nov, 2009 at 08:03:57pm
Well we'll (Me & Paul S) have a 2nd car running the siamese code soon hopefully :) |
14th Nov, 2009 at 08:28:32pm
On 14th Nov, 2009 sturgeo said:
Well we'll (Me & Paul S) have a 2nd car running the siamese code soon hopefully :) We have a race on now then...... Which actually is a very good thing..... the more who get involved, the better. Schrödinger's cat - so which one am I ??? |
14th Nov, 2009 at 09:29:09pm
I will almost certainly be last in that race haha.
14th Nov, 2009 at 10:06:35pm
I'm not racing, I'm taking my time.
15th Nov, 2009 at 12:16:44am
On 14th Nov, 2009 Paul S said:
Might even try to weld up the inlet manifold, but my gas bottle shows empty so I don't expect to get very far. You won't with a bottle,,,,,, compressed gas comes in a cylinder ![]() Milk or beer is what comes in bottles..... Schrödinger's cat - so which one am I ??? |
15th Nov, 2009 at 10:40:17am
Calor gas comes in a bottle.
15th Nov, 2009 at 11:56:53am
On 15th Nov, 2009 Paul S said:
If you persist in this arguement, I shall start calling you Rodney as that is technically your real name ![]() Worse actually, it's Roderick ![]() Schrödinger's cat - so which one am I ??? |
15th Nov, 2009 at 05:25:00pm
i dont think there much to laugh about when your sobriquet can be used to replace various common sayings ,eg
24th Nov, 2009 at 10:00:06pm
As per various PM's and emails To both Rod and Paul, I am at a bit of a standstill on the MS2 build. I have the main build all but complete. Just the addition of the 4 channel driver board left, and a small problem to overcome..
24th Nov, 2009 at 10:26:22pm
Hmmm, have you adjusted the 2 pots? It took us a while to get the rpm signal to work. I think we had to cycle power between each adjustment.
Edited by sturgeo on 24th Nov, 2009. |
24th Nov, 2009 at 10:40:15pm
DIP switch 3 is correct to represent the 36:1 wheel.
25th Nov, 2009 at 02:30:32am
You need the 12V pull up for the primary and the 5V pull up for the secondary.
25th Nov, 2009 at 02:33:20am
By the way, I should add that if you have any question related to one of my boards, you can post it on my forum: http://forum.jbperf.com/index.php.
25th Nov, 2009 at 08:14:41pm
On 25th Nov, 2009 jbelanger said:
You need the 12V pull up for the primary and the 5V pull up for the secondary. Jean Are they not built into the standard board circuitry? We did not add anything extra. My money is on the pots. This is what the Megamanual says: "With a VR sensor on the VR input circuit: Start with the R56 pot all the way counter-clockwise, and R52 about 6 to 8 turns clockwise from the fully counter clockwise position. The fully counter clockwise position is reached when the pot clicks (you can feel and might be able to hear this). The pots are 25 turns from the fully clockwise position to fully counter-clockwise position." Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Nov, 2009 at 08:39:43pm
You need the 12V pull up for the primary and the 5V pull up for the secondary. Jean Are they not built into the standard board circuitry? We did not add anything extra. I assume Jean is referring to the jumpers on the JimStim board that need to be set for primary and secondary tach signals. Schrödinger's cat - so which one am I ??? |
25th Nov, 2009 at 08:48:15pm
Yes, that's what I meant. You need the jumpers on the JimStim to generate the tach signal(s).
Page: |
