Home > Show Us Yours! > G\'s & dads first mini turbo build
GINO R32
Member #: 4865
LUTON beds
My old man said the same thing lol
On 14th Sep, 2009 rubicon said:
should have run those cables and pipes inside the car,
a nasty rock could easily split that copper..
looks like youve got some trick bits tho
Shouldnt the piston dishes be offset forwards rather than back?
Paul
GINO R32
Member #: 4865
LUTON beds
Minispeed said this is the way they go
Im gona call them up again :(
Paul
Paul
Indeed they should.
Good, otherwise mine are backwards. lol
Paul
GINO R32
Member #: 4865
LUTON beds
iv had a chat with minispeed and said iasa sign should face engine number
Which they do so the sign been put on backwards then (great 1 )
Engine is now in the car so should I take it out again? minispeed said I can keep them the way they are coz it dont make much difference what to do
If you have gone to the effort of buying fancy pistons you might aswell fit them properly. Id take them out
Paul
If you have gone to the effort of buying fancy pistons you might aswell fit them properly. Id take them outPaul
+1
It would really bug me if I knew they were in the wrong way around
Apart from the offset dish, what else is fancy about them ???
Do they have offset gudgeon pins for example ???
Is the forging biased one way for heat distribution as another example ???
It sounds like Minispeed don't know what they are talking about if they say they can go either way around, I would actually talk to the manufacturer before doing anything.
Was it not Minispeed who were also selling JE pistons designed for the A series with 18mm pins and a crown hight 7mm lower than the deck hight?
If you look on the minispeed website, the picture shows the IASA etched into the fattest part of the squish band and is the other way round.
I think I recognise that plenum & dump valve .... *wink*
Nick
Member #: 154
Midlands
i recognise that turbo aswell *wink*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Just came online to find this guy, this was the only thread i could find, his car was looking really good at MITP today loads of attention!!!
good to meet you mate! :)
mcalvert39
Member #: 442
Manchester
Is that bulkhead box welded in or sclicone'd in with self tappers?
Do you have "lambo" doors on yours aswell?
haimesyboi
Member #: 5702
Cornwall
It does look that way, im not sure if the thoughts are different on weber boxes being less structural but i would still seam weld it.
The car looks really well done but those fuel lines are asking for trouble.
