Page: |
Home > General Chat > Another frustrating day.... | |||||||
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
13th Jul, 2009 at 12:33:33pm
The problem here appears to be the fact that your block is tapped 3/8 UNF.
2490 Posts Member #: 1954 Post Whore Luton Bedfordshire |
13th Jul, 2009 at 12:49:14pm
Dude not my block. All the tapped holes are factory standard all my fittings were assembled by Beachgrove engineering to my requirements. All my spares are removed facory fitted items so should fit yours.
On 11th Jul, 2009 Mr Joshua said:
I have the same set-up as you but I have a male BSP to male BSPT adaptor between the block and banjo. Own the day
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
13th Jul, 2009 at 01:02:42pm
The block is definately 3/8" UNF at 24 TPI parallel.
13th Jul, 2009 at 01:19:50pm
PM me your details and ill throw them in a jiffy bag nothing like having the parts in your hand. Never seen two different types of bore for that location but I dont know everything.
Own the day
13th Jul, 2009 at 01:32:30pm
The thing is, what you are all looking at is fittings that you "expect" to only go in a short way..... and expect to lock up and seal. The expectation is that they lock up and seal because of tapered threads.......
Edited by Rod S on 13th Jul, 2009. Schrödinger's cat - so which one am I ??? |
13th Jul, 2009 at 01:58:35pm
I would have drawn the opposite conclusion from this bolt:
13th Jul, 2009 at 02:15:57pm
It went in over 20mm, it was only "tight" (and not that tight) for the first four turns as it corrected the damaged leading threads in the block.
13th Jul, 2009 at 03:09:53pm
Right, here's a 3/8" UNF second tap next to the bolt (sorry, I don't have a plug tap).
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
13th Jul, 2009 at 03:50:27pm
I have to agree with paul S, The original avonbar banjo bolt was 3/8 unf, but because they are very close to the bsp they got away with it, after a while and stripping rebuilds etc they start to wear. I promise you that is deffinatly bsp. or 1/8th gas as its commonly referd to.
"Cars are a lifetime of pain" |
13th Jul, 2009 at 03:59:25pm
i'd agree with rob if the tap went in that far just turning the shank with fingers and with such a minimal amount of swarf its clearly 3/8 UNF . perhaps, there was a changeover at some point from one thread to another? turbo 16v k-series 11.9@118.9 :)
13th Jul, 2009 at 04:03:52pm
Well, on my two blocks, there is simply no way I could screw a 3/8" UNF tap down a 1/8" BSP threaded hole without removing every 6th thread and most of the threads either side.
13th Jul, 2009 at 04:05:08pm
but later on in life, i can understand that on the later mpi's, but 1/8 bspt has been on both my A+ lumps. Maybe someone has taped it previously? also the thread is probably not what it was when it came out of the factory.....and if all oil pressure switches are 1/8 bspt then surely we would have an option on threads from the suppliers?
13th Jul, 2009 at 04:09:21pm
On 13th Jul, 2009 ministef1 said:
but later on in life, i can understand that on the later mpi's, but 1/8 bspt has been on both my A+ lumps. Maybe someone has taped it previously? also the thread is probably not what it was when it came out of the factory.....and if all oil pressure switches are 1/8 bspt then surely we would have an option on threads from the suppliers? stef so long as they screw in a few threads and get tight i imagine many (myself included) would be nieve to the thread difference and put it down to the tapered thread. im sure there are different threads though, as i remember swapping an oil pressure gauge from one mini to anoter many years ago and it fitted but really didnt feel right and the threads where quite chewed up on removal. turbo 16v k-series 11.9@118.9 :)
13th Jul, 2009 at 04:17:31pm
I am convinced it is down to people assuming things tighten up because of "tapered threads".
13th Jul, 2009 at 04:22:37pm
Agreed the threads in the block are parallel. I would not expect a tapered fitting to screw all the way home. If it does the fitting has been over tightened in the past or the tap has been run in to far, over done it on a pressure regulator before.
Own the day
13th Jul, 2009 at 04:23:51pm
Well, I've just gone and used a thread gauge on the two accessible blocks that I have.
13th Jul, 2009 at 04:35:48pm
So maybe there was a change and that's why Avonbar moved from 3/8" UNF to 1/8" BSPT.
13th Jul, 2009 at 04:47:02pm
If I can find them ill compare both taps Own the day
13th Jul, 2009 at 05:02:01pm
I've emailed Avonbar, who sent me the original UNF fitting (but too short) followed by their BSP fitting, to see if they can shed any light on thread size changes.
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
13th Jul, 2009 at 06:03:49pm
Just to add a little more fuel for discussion, I went out and checked my two A+ blocks and, as Rod says,a 3/8 UNF bolt will screw all the way in by hand.I use one just to keep the crap out. |
326 Posts Member #: 1323 Senior Member |
13th Jul, 2009 at 06:07:35pm
All you engineers !!!
13th Jul, 2009 at 06:32:01pm
On 13th Jul, 2009 carl talbot said:
All you engineers !!! you need a mechanic to do the job :) Exactly, a mechanic will just go and find a large enough spanner to make it fit and the engineer will spend days calculating why it won't fit ![]() On 13th Jul, 2009 tadge44 said:
Just to add a little more fuel for discussion, I went out and checked my two A+ blocks and, as Rod says,a 3/8 UNF bolt will screw all the way in by hand.I use one just to keep the crap out. Dave, just makes me think more that there must be a difference between early (inc early A+) and late blocks. Schrödinger's cat - so which one am I ??? |
13th Jul, 2009 at 06:32:51pm
I just tried to put a 3/8 UNF screw in the hole.
13th Jul, 2009 at 08:20:15pm
I believe both thread types were used. MiniSpares sell this fitting:
13th Jul, 2009 at 08:57:45pm
Yes, I think all this debate points to there being two different threads.....
Page: |
