Page: |
Home > Show Us Yours! > 1380 bike carbs N/a (update 01/03/11) | |||||||
4890 Posts Member #: 1775 Post Whore Chester |
23rd Mar, 2009 at 08:23:38pm
just a quick question... can you use silicon hose in direct contact with petrol?? doesn't it swell and dissolve? I run a supercharger and I don't care the TB is on the wrong side.
6274 Posts Member #: 509 Post Whore Isle of Man |
23rd Mar, 2009 at 10:04:41pm
you shouldnt really, as oils will deteriorate the silicone, but you can get specialist oil resisitant silicone hoses, no idea where from though?
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
24th Mar, 2009 at 01:10:44pm
On 23rd Mar, 2009 Alex1340 said:
got the carbs all connected up now. I'm going to need to do somthing with the throttle pedal to get some movment back at the pedal. only moves 2inchs from closed to open throttle bit of cutting and welding maybe needed. (spares throttle peadel on stand by) Other than that they have gone on very nicly. Just got to finsh the rad pipes and oil lines... exhuast.... wiring..... Wideband lambda........ you get the idea... lots more to do. I reversed the mount and drill a new hole for the cable further down the bar (5cm), that will get you half the throw, and doubled leverage internationally known as "big" swede |
902 Posts Member #: 111 Post Whore Loughborough |
5th Apr, 2009 at 12:28:24pm
This is the task for today. how do you calculate the place to drill?
5th Apr, 2009 at 05:42:10pm
On 5th Apr, 2009 Alex1340 said:
This is the task for today. how do you calculate the place to drill? Maybe a bit late, you have probably figured it out yourself by now… Cut the bracket and reverse it, weld Mount it up again and mark were the new hole is going in the bar If you after all that careful eye-lighning miss the damm hole, enlarge the holes in the bracket and adjust side ways by bending the bar8-) i now also run a stiffening rod that connects the two bars, broke it clean off in the joint, much better feel now NO FLEX Edited by G13B on 5th Apr, 2009. internationally known as "big" swede |
6th Apr, 2009 at 11:01:15pm
Right I measured the amount of cable need to fully open the SU then the new bike carbs (50mm for the su and 20mm for the bike carbs) used this as a ratio 2/5 so took the away from the leaver arm length and drilled a new hole 46mm fromthe pivot. Just have to drill a new hole in the bluck head for the cable and it should work. Only problem is I sheared off on of the bolts for the throttle pedal. First things first I need to fix that........ Some how |
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
6th Apr, 2009 at 11:36:59pm
Looks really good what you have done with every thing. i bet it sounds the tits with them on. Best 1/4 mile 13.2 seconds @116 mph
7th Apr, 2009 at 10:32:46pm
hope to get a vid of it running this weekend. I need the bits for converting my mega jolts to TPS.
11th Apr, 2009 at 08:29:31pm
Almost ready to run it but..... problems..
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
11th Apr, 2009 at 08:34:54pm
Easy just take the pipe of where the banjo bolt went in, put the car in 4th, get you squirt can and as you push the car backwards keep squirting oil in the banjo bolt hole in the block. On 17th Feb, 2009 Rob H said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
11th Apr, 2009 at 09:38:09pm
or raise the oil cooler up, so the oil flows out of this back into the block, as you push the car backwards in 4th. |
11th Apr, 2009 at 09:56:31pm
Ahh Nice Idea but still Important to then re fill the Oil cooler as an Empty Oil cooler is not good for a new motor :( On 17th Feb, 2009 Rob H said:
11th Apr, 2009 at 10:31:38pm
On 11th Apr, 2009 PaulH said:
Ahh Nice Idea but still Important to then re fill the Oil cooler as an Empty Oil cooler is not good for a new motor :( |
12th Apr, 2009 at 12:33:01am
just to check does the oil run from the bottom (where the filter used to be) to the higher point where the banjo was? Or the other way round? I've fed oil in to the oil cooler and all pipe but not tried pushing the car backwards in gear. Will enlist a helper on Sunday and try it (my drive slopes a lot)
12th Apr, 2009 at 10:34:12am
feed oil into he blocks main gallery (the hole near the pressure switch) whilst pushing the car slowly bacwards in 4th, if you have a big syringe its a piece of piss.
12th Apr, 2009 at 10:37:13am
just checked your pics, and the oil cooler is on its side, i had a similar set up a few years ago (mounted on the brace bar), and it can be a right pain getting rid of the airlock.
12th Apr, 2009 at 10:47:22am
Oil cooler has ended up in front of the gear box now really low in the engine bay. I've got a squirty oil can so I will try that. Thanks |
13th Apr, 2009 at 06:22:02pm
IT'S ALIVE!!
13th Apr, 2009 at 07:39:52pm
congrats, good oil pressure? "Turbo's make torque, and torque makes fun"
13th Apr, 2009 at 08:15:52pm
80psi once it fired up |
13th Apr, 2009 at 09:53:19pm
Need help with re-wiring the new alternator. I have two spade terminals and one post. I ha e three wires on the oringal loom, one thick brown a brown and yellow and a brown and blue I think. Help? |
19th Apr, 2009 at 08:52:38pm
Hi Guys,
19th Apr, 2009 at 09:03:01pm
You can see my setup in the middle of the pic, its a brake cabel from a bike and a spring
32 Posts Member #: 2517 Member Mold, North Wales |
19th Apr, 2009 at 09:07:39pm
Fit a spring like this.
Edited by steve d on 19th Apr, 2009. |
19th Apr, 2009 at 10:08:13pm
Did you mount the point on the throttle or was that built on to them? Think I will need to fix somthing to the carb for the spring to pull on.
Page: |
