Page: |
Home > 998cc > A+ or 997 Cooper | |||||||
13th Feb, 2009 at 07:20:57am
a correctly sized turbo will produce the torque, i'd not build it from the 997,then a 1098 will not offer much more over a well build 998 turbo.
13th Feb, 2009 at 08:06:40am
On 12th Feb, 2009 Paul S said:
Take the 12G295 and fit that on an A+ 998. If the 12G295 has not been skimmed, you will have about 9:1 compression ratio. Having done this for a car I use every day, I would suggest it's the best option. 45mpg 16.2 1/4 mile and drives like a normal car. I even use a verto clutch so it's easy on the left foot. The only issue I've ever had is carb icing. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Feb, 2009 at 02:56:28pm
Take the 12G295 and fit that on an A+ 998. If the 12G295 has not been skimmed, you will have about 9:1 compression ratio. Having done this for a car I use every day, I would suggest it's the best option. 45mpg 16.2 1/4 mile and drives like a normal car. I even use a verto clutch so it's easy on the left foot. The only issue I've ever had is carb icing. This is what I was originally thinking, based on yours Wil. What carb though? Paul I seriously doubt it! |
13th Feb, 2009 at 03:00:51pm
STD metro turbo carb i would have thought. If something is worth doing, it's worth doing half of. |
14th Feb, 2009 at 08:15:40am
don't throw out twin's idea, in a mk1, they'll be the littl etrick that'll have an edge over..sure you'll make a nice airtight alloy airbox looking like a genuine one |
14th Feb, 2009 at 08:43:08am
Emember although it's a 998 it'll be producing 80 to 90 bhp in mild form, so a 1 3/4 carb is well sized. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Feb, 2009 at 08:57:20am
know that,
14th Feb, 2009 at 10:04:14am
On 14th Feb, 2009 fab said:
don't throw out twin's idea, in a mk1, they'll be the littl etrick that'll have an edge over..sure you'll make a nice airtight alloy airbox looking like a genuine one TBH the thought had crossed my mind as it has twin 1 1/4" on ATM and they do look great but an HIF 44 usually out performs twins on anything uptp 100 bananas in my experience Paul I seriously doubt it! |
14th Feb, 2009 at 12:44:11pm
then you know you need to produce over 100 bananas then |
![]() 160 Posts Member #: 1085 Advanced Member Netherlands |
14th Mar, 2009 at 09:37:06pm
owning a 997 with a busted piston I vote you give that engine to me 1963 Cooper
14th Mar, 2009 at 09:43:34pm
sorry, double posted Edited by Arnoud on 14th Mar, 2009. 1963 Cooper
Page: |
